Ace 1926
- June 24, 2016
- moorpark ca
- 1998 explore xlt
I have a real head scratcher. 98 Explorer XLT 4.0 sohc runs great except on 90 degree plus days here in So Cal. It will just stop running with NO code being thrown. Let it cool of an hour ( or 40 miles on a tow truck) and it will start and run great again. Fuel pressure is good when its running. The Dealer is lost without a code so my personal mechanic took a stab at it with fuel pump, relay , filter. Got a good hot day to take it out and give it a test and sure enough about and hour it just died not a cough not a sputter. The mechanic and I are now thinking something electronic heat soaking and shutting down or going open but where to start? The master bus under the hood with fuses was very hot to the touch this last go around. pushed it into the shade , sat and cussed Henry Ford for 90 minutes and it started up and has run fine since.I have had it die when backing out of a parking space on hot days in the past but it always starts then. It's got low mileage and in good shape and is a good fit for us so I hate to ditch the thing. Any input would be appreciated.. Thank you
