You could have basically made that kit for less than $10. Here is the diagram I used when I made a kit for my truck. http://www.kchilites.com/faq/instructions/6314.pdf
Now the instructions that came with your kit should be identical, its rather easy and only takes a few minutes to do, an hour if your picky and take your time soldering the connectors to the wires. You should be able to run both headlights off of one harness, but when I did mine, I made two harness just to be on the safe side.
Dan
Oops, didn't realize the link had already been posted
