I have the 4" superlift w/ extended arms done on my 1993 Explorer. The front end is way off. The bottom of the tires are pointing way in, and the top are pointing way out. I just need to know how to adjust it good enough to get it to the shop to be aligned. It is about 5 miles downm the highway (55mph). It seems that i could loosen the tie rod ends on both sides and slide the tie rod till it evens out the tires. I just wanted to check before I did that. I loosened the 2 bolts on the tie rod on the passanger side to see if they would even budge. Then I saw that the tie rod is threaded under that. Would I use a pipe wrench to move the threaded part to adjust the tie rod. any info would be appreciated. I thought I saw a thread here earlier covering it, but I cant find it now.
Thanks,
Nick Good
Thanks,
Nick Good
