engineeering
- July 3, 2014
- 06 explorer xlt 4x4
hey all.. Love the forums!
I've searched the entire internet high and low and can't find anything. Hope you guys can help!
I have a 2006 XLT 4x4 explorer fitted with an electronically controlled radiator fan clutch. I would like to wire a bypass switch to engage my fan to high when needed.
In short... I live in a very mountanous region in the west coast where it can get really hot. I often have to tow my trailer and side-by-side UTV straight up logging roads for up to 8000 ft elevation (I inspect dams for a living). For some reason my fan only seems to be operated by the engine coolant temp and my trans temp can often be much hotter. I've installed a 23000lb rated inline ATF cooler... but it doesn't do any good without air speed across the rad.
Any help would be great! ps. this is the most i could find on the web...
http://www.justanswer.com/ford/1grjp-create-bypass-switch-turn-off-fan.html
It's for a diesel ford truck and the wiring colours are different. I want to start grounding some wires while observing the fan but I don't want to break anything or pop codes.
additonal notes... i have my egr deleted and I've heard that this can affect fan temps for some reason (emissions control turned off via flash SCT tune).
