joachimf
- February 23, 2006
- Cologne, Germany
- '07 Eddie Bauer 4x4
Dear @all,
our ‘07 EB 4.0 had started using water in summer ’11, only a little. No puddles, no drips on the garage floor but visible in the overflow tank . After an extended search (full scale investigation) I found out that the radiator had cracks in the net, coolant hasn’t any exhaust components. Cracks seem to be in the middle of the rad so that the fan distributed the coolant fog out of the engine bay. Shroud had a thin layer of coolant and fan had some dried up coolant.
Went through the FoMoCo work shop manual and they suggest to take the radiator out with left and right radiator support attached to the radiator. They also suggest to use special tools for fan removal (36mm & 56mm wrench), radiator line removal (unclip tool) and tranny refilling (fill plug). Had ordered all this stuff including the rad from my preferred Ford dealer.
Removal and installation was easy, took me 5 hrs (including some breakes for coffee). Lost .4 litres of tranny fluid while removing the tranny lines from the radiator. After refilling the radiator with gold coolant I test drove the Ex and later checked for tranny level. Pushed the .4 litres back into the pan with a suction gun. Check hole starts dripping so I assume everything is all right.
