As far as I know, the answer would be NO. As you will see when you change bands AM/FM/Sirius, each has its own bank of pre-sets that can be used. I don't see anyway of merging pre-sets.Is it possible to have say XM and FM stations intermixed on the presets so that I don't have to be listening to say the XM bad to go to an FM station?
Any chance this feature has been added in 3.10? It's one of those features that you don't care about it unless you had it, which I did in my Acadia. Co-mingling the various bands into a single pre-set panel seems like such a simple thing. I never thought it would be such a luxury.
I don't listen to many different stations but when I want to change a station I simple use voice commands and it's done in a second or two, providing you know the station you want.Any chance this feature has been added in 3.10? It's one of those features that you don't care about it unless you had it, which I did in my Acadia. Co-mingling the various bands into a single pre-set panel seems like such a simple thing. I never thought it would be such a luxury.
I don't believe I said it was faster in that quote. All I have to do is press the steering wheel control, wait a second for the prompt, say the station and the change is almost instantaneous. There is no waiting for a confirmation prompt anymore. The advantage is that you don't have to take your eyes off the road to find and press the preset. I just did an actual test while parked. Both ways took approximately 7 seconds. By not using voice, from the 'Home' screen I had to press the 'Audio' button, then select the 'Source' and then the appropriate preset. Keep in mind that if driving it likely would have taken a bit longer so as to take quick glances to check traffic etc. Either way works just fine since I don't see 'speed' as a requirement when changing stations. I just find using 'voice' easier and safer.Sorry, I'll respectfully disagree, there is no possible way your way is faster.
Your Way:
1. Press a button
2. wait for a prompt
3. say your desired station
4. Wait for it to be interpreted
5. Wait for station to change.
