Radio wiring diagram | Ford Explorer Forums - Serious Explorations
Dakszaks
Rogers Arkansas
2016 explorer limited
I have a 2016 Ford explorer limited with the sony system and the 8 inch touchscreen.
I am trying to add a line out connector from the rear speakers for an external amp and subwoofers, all of the wiring diagrams I have seen I do not have those wires behind the radio. If someone could help with a wiring diagram
Edit: We found a solution, we used the wiring from the factory sub for the line out converter.
Welcome to the Forum. :wave:
Not saying you won't get results, but to get the best results from a line out converter you want a signal that has a full range signal. Typically, you want to grab this from the front speaker channels.
