Rear Bearings for 2003 Sport Trac 4x4 | Ford Explorer Forums - Serious Explorations
DSteele41
OKC,OK
2003 Sport Trac
4x4
Does Anyone Know of any Videos to Install New Bearings in the Rear of this Vehicle ? or Directions to do it
also can someone verify that these are the Correct Bearings for 4x4 (4WD) 2003 Sport Trac ?
Thanks
DSteele41
I did a Mustang 8.8 (1988), same style bearings, I used a socket of exact size as the O.D. of bearing, make sure everything is clean, and start them straight, crocked is bad, wont go.
Did the '03 ST have independent rear suspension or a solid rear axle?
When I replaced the bearings and axle seals on my '01 ST's rear diff I borrowed a slide hammer from O'Reilly's with an attachment that slides in and behind the bearing. Then it grabs behind the bearing and you use the slide hammer to pull it out. To install the new bearing I also borrowed a bearing installer to drive the new bearing in.
It was a fairly easy job after you get the axles out. Be sure to clean the axle housing out very well before installing the new bearings.
IDK if the bearing you pictured is the correct part number, but it looks the same as the axle bearings I used.
Thank You for Reply
any pics by chance (even if from internet) So I'll have visual of getting them from and into the Axle ?
I dont want to start and then get to axle and can't finish job for being afraid of messing up something
Thank You for Reply
For removing the old bearing, you attach the appro sized tool tip to a slide hammer, slip it in behind the bearing, tighten it up and bang the bearing out.
To install the new bearing, select the appro size installation tool from the kit below, install the handle, place it on the new bearing and whack it home.
Most auto parts stores lend these tools with a deposit.
@koda2000
@974X4BLACKSPORT
Would this link be very similar ?
What I dont understand is Why is in the Rear Axle Cover ? Does that have to be done to change Bearings ?
How to replace rear axle seals and bearings in your 04+ F150 (lots of pics) - F150online Forums
Thanks to you both for Replying
DSteele41
@koda2000
@974X4BLACKSPORT
DSteele41
Huh? Yes you need to remove the rear axle cover in order to remove the axles. If you do not have limited slip you remove a small bolt, slide out a large pin, which releases the spider gears and then allows the axles to be pushed in so that the "C" clips can be removed with a magnet, then the axles can be pulled out once the disc brake calipers, brackets and rotors are removed.
If you have limited slip (and I would assume you would on a 4x4) the process of removing the axles is more difficult.
IDK if you skills are up to this task. You can find videos on YouTube that should give you a good idea of what's required but if you've never done anything like this before you may quickly be over your head. Plus you may want to consider replacing your limited slip clutches while your in there (as they wear out over time).
I'll look at the link you provided for the F150 and see if the job would be similar/same on your ST. You never answered my question as to whether the '03 ST has a solid rear axle or independent rear suspension.
Edit:
I reviewed your link for rear axle bearing and seal replacement for the F150 and provided your ST has a solid rear axle (like that pictured for the F150) the bearing and seal replacement procedure would be identical.
TIP: If you go ahead with this job, be very careful not to bugger up the head of the small bolt that holds in the large pin for the spider gears and axles in place. If you do bugger/round-off the head of that bolt it will be nearly impossible to remove it. I usually replace that special bolt any time I have to mess with it and use thread locker on it when reinstalling it.
Edit:
@koda2000
When you say "Bugger/Round-Off" Do You Mean "Be Careful Not To Strip the Bolt" ?
Thanks for All the information as well
DSteele41
@koda2000
DSteele41
Yes. The head of the pin retaining bolt is very small (5 or 5.5 mm?) and it's easy to round off the head if your wrench/socket doesn't fit well.
Below is an eBay pic of a LSD clutch kit. In between the clutches/plates is a new pin retaining bolt. Notice how small the head of the bolt is (and the fact that reusing the old bolt is not recommended). Also included is a bottle of LSD friction modifier, which is required to make the clutches operate smoothly. The last time I had a diff apart I bought a new pin bolt and a new wrench to install it with and I was still afraid I was going to round the head of the bolt. I wish the bolt had a larger head, but it is what it is.
What makes the LSD more difficult is removing the "S" spring (which keeps tension on the LSD clutches) and reinstalling it during reassembly. Prying the spring out isn't too hard, but you need to compress it as much as possible and hammer it home during reassembly. A needle nose vise grips work well for compressing the "S" spring. Pic below (you only require 1 pair).
Pic of "S" spring below:
