Rear Differential Fluid Change Question | Ford Explorer Forums - Serious Explorations
XCAMP
2005, XLT
Hi there, I have a 2005 Explorer with AdvanceTrac.
I noticed in the manual that when changing the rear differential fluid, it calls for removing the ABS sensor and adding fluid from there as well.
Is this really necessary and have any of you changed your fluid without doing so?
Any help would be appreciated.
Hi there, I have a 2005 Explorer with LSD and AdvanceTrac.
If you have AdvanceTrac, you have four-wheel ABS, which means the rear ABS sensors are mounted on the wheels, not on the differential.
I will have to get the exact wording from the manual. Maybe I am misunderstanding it.
Anyone here changed their fluid on an explorer with advance trac?
OK, here it is...
Material
Fluid Check
NOTE: When the fill plug is removed, up to one pint will drain from the filler opening.
Remove the fill plug.
Fluid Drain and Fill
Remove the drain plug.
Install the drain plug.
Tighten to 34 Nm (25 ft. lbs.) .
Fill the axle to the bottom of the fill plug hole.
Install the fill plug.
NOTE: For roll stability control (RSC) equipped vehicles, remove the rear wheel
speed sensor plug.
For non-RSC vehicles, remove the rear wheel speed sensor.
Remove the rear wheel speed sensor.
1 Disconnect the rear wheel speed sensor electrical connector.
2 Remove the bolt.
3 Remove the rear wheel speed sensor.
Add one pint of fluid.
Install the ABS sensor and ABS sensor bolt.
Tighten to 27 Nm (20 ft. lbs.) .
2005 rear diff plug removal
What tool did you use to remove the drain plug?
I couldn't find a 3/4 inch drive tool, so I went to Home Depot and bought a piece of 3/4 inch square welding stock. I pushed that into the drain plug (it fit perfectly), then used a large crescent wrench to turn the welding stock.
They are hard to find, but Sears has the right size adapter that goes right on the end of a wrench. You just put it in the drain plug and turn counter clockwise.
OK, here it is...
Material
Fluid Check
speed sensor plug.
2 Remove the bolt.
Do I need to buy 2 or 3 bottles of Mobil1 75w-140?
Per my calculation (and I could be wrong) it will take a little more than 2 bottles and the friction modifier.
The owner manual capacity for rear axle is 3.5 pints (56 ounces) + 1 pint (20 ounces) for top fill comes to total of 76 ounces.
1 bottle of Mobil1 is 32 ounces so 2 bottles plus friction modifier totals to 68 ounces.
Mobil 1 has the friction modifier already in it
1 pint = 16 oz. Total 72 oz
That leaves you only 4 oz short. I would probably let that slide.
