Dalmus
- August 26, 2009
- Milwaukee, WI
- '03 4.0L Flex; 190K Miles
Took '03 XLS in to have my noisy rear end looked at, and after driving it around, the mechanic put it on the lift, went to the rear diff, and found there was a bit of slop in the pinion bearing.
He said that if I wanted to replace the outer bearing, I might as well replace the inner bearing as well since everything will be open. But he said that its often a bear to get the thing apart, and if something goes wrong and he has to force it apart, he might damage a shaft which would then put me in for all the gears, too... Not to mention it would be rather expensive, even though he does my work on the side. He was talking somewhere between 800 and 1200, spending on what the parts cost and how long it took him to do it (he said from experience on a couple Jeeps, its a good portion of a Saturday).
My question is, why even risk damaging anything... Wouldn't I be better off monetarily if I just got a rebuilt differential and did a complete swap? That way I don't have to worry about any damage in the disassembly of the bearings. In theory, it should be less labor time, too, right? I think I would also get the bonus of having the faulty ABS sensor in the diff replaced in the deal.
I have 150,000 miles on her now. She's in otherwise decent condition... Good pep, good body. I'd like to see her to 200,000, but I don't want to throw money away, either.
Thoughts? What would be a good source for a rebuilt diff? What about taking my chances with a "used" diff?
Thanks!
Thanks!
