Bent Bolt
- December 16, 2006
- Edmonton,Alberta
- Think Canadian ,eh !!!!
Honestly, the only real way of filling a torque converter is by installing it in the vehicle and starting the engine.
To be really honest, I don't even soak the clutches when I build transmissions. Once the trans is installed and engine running for about 15 minutes, there is enough ATF splashing around to coat and soak every friction material inside. go for an easy road test for about 10 km then after that, go hard. If the trans doesn't work properly by then, most times there is something wrong.
As always, there are exceptions to the rule.
Your results may vary.
