ajrn
- June 28, 2003
- Toledo, Ohio
- 1998 XLT
Okay--
I replaced the front calipers on my girlfriend's 99 Explorer.. I replaced the hoses as well.. New pads/rotors, you get what I'm saying..
Things came apart okay, went back together okay.. Used 'loaded' Morse rebuilt calipers-- Wagner hoses, Valvoline Syntec brake fluid.. I used 'speedbleeder' type check valve bleeders.. Spent my time, and bled till the fluid came BACK looking like it came in.. (The stuff there was pretty damn ugly-- and I'm wondering if this may be the "issue..")
Tires back on, pump the brakes a few times, to get the pads "close.." Start the engine-- the brake light doesn't go out..
The ABS light does the test cycle, then goes off.
The parking brake wasn't engaged-- the pads are gone anyway, I need to do that 'next....'
There's fluid in the reservoir.
The brakes ALL appear to be working.. Pedal 'feel' is normal, it's not hitting the floor. I didn't MASH it to the floor when I was bleeding it...
I found the bleeder valve on the master cylinder, bleed some MORE fluid out there..
Nope.. Nothing changed..
I was guessing it was either something that upset the Anti-lock system, or maybe I bumped the proportioning valve..
I took it out-- up to 40mph and did a few (3-4) hard stops..
You're guessing nothing changed, right?? Good-- bonus points for you..
Did that sludgey nasty brake fluid do something bad??
Any ideas on what to do next?? Again, there's no problems with stopping..
Sigh-- I'd just like to be done..
AJ RN
AJ RN
