pcrussell50
- September 27, 2012
- socal
- 1997 expolrer xlt
The TC shift motor is also a weak link, I'd verify that is good before being serious about a TC rebuild or swap. Those motors are rebuildable, used to be about $75 new, last time I looked ran $75 used. I'd rebuild one next time if I need it.
Thanks for all your help so far by the way...
Is this also the same motor that shifts from normal to low range? If so, I can confirm that it works properly. I can hear it shift and then it drives fine in 4LO. Does it perform some other function besides shifting between HI and LO?
-Peter
