davidmedearis
- June 28, 2010
- Downingtown, PA
- '96 XLT
Hello,
I'm new here but it seems I'm in some trouble. Here goes it:
1996 Explorer XLT
4.0 V6
Four wheel drive
I just replaced my rack and pinion. The old one was gushing all over the place, and a re-manufactured unit was only $150 after the core return.
I replaced it fairly easily, following the ford shop manual for the install. All seemed to go well. The problem surfaced upon restarting the steering system. I disconnected the ignition control module (ICM) and filled the power steering reservoir. I cranked the starter so that the pump would gulp up the fluid, and repeated this process until the fluid level remained constant.
I turned the wheels from stop to stop several time, noticing pressure build up as I went, and watched as bubbles came to the surface of the reservoir. When the bubbles stopped, I reconnected the ICM and started the engine.
The engine started fine, but the steering system.... not so much. As soon as I attempt to turn the wheel in any direction, it enter a a violent oscillation that could seriously hurt someone with their arms in the wrong place. I have attached a link to a video of the problem that I recorded:
Is this just air buildup? It is not the check valve that goes into the pressure input line on the rack. I have already checked this an confirmed that it is not the cause. I really am at a loss on what to do. Please help!
1996 Explorer XLT
4.0 V6
Four wheel drive
