offroadford4x4
- April 8, 2004
- Lewisberry, Pa
- 02 Eddie
I got the pan off, fluid looks and smells like new. No chunks or pieces in the pan. I pulled the solenoid block and tested it. results were
shift solenoid A 27.6 Ω
shift solenoid B 27.6 Ω
shift solenoid C 27.6 Ω
shift solenoid D 27.4 Ω
PCS A 8.4-8.5 Ω (toggles back and forth)
PCS B 8,4 Ω
PCS C 8.4 Ω
TCC 13.9 Ω
temp sensor 32.1 KΩ
Now from what ive seen so far, everything is in the proper range except the PCS's, which are reading 0.9 Ω higher than what ive seen. Would this cause the issues I'm having? at first startup, I was able to drive normally down the street, accelerating to 50-55mph and it shifted just fine, but right after I slowed down and tried to accelerate again it triggered the OD light to flash and when it shifted up to 3rd, it was like it was almost in neutral. basicaly just free reved. If not next I'll be checkin into the bands and servos.
PCS B 8,4 Ω
PCS C 8.4 Ω
TCC 13.9 Ω
temp sensor 32.1 KΩ
