it was on the electrode end and i beleive it sand/debris on the plug it did not look like metal, on of the plastic connections is missing the clip to hold it on to the coil but i zip tied it for now and checked to see if all of the connections were on and the coil packs were pushed down enough. seemed to be in my eyes
If you're having a misfire, it's possible a COP is going bad. Very common It may not be as noticable when accelerating, but could be more pronounced when idling.
Figured it out lol, how can you tell if the coil packs are bad or going bad besides if it might show/tell it on the scanner when i scan it?
2002 V8 is a COP ignition...
Ya I actually had oil on about 4 of them. Do the boots just pop off of the coil packs or what? I didn't really mess with them, just cleaned them up a bit.
Yep just pop the boots off the coil. The spring may stay attached to the blade terminal inside the bottom of the coil but it too, just pulls out. Be sure to buy ONLY boots which come with the springs connectors and use di-electric grease its cheap preventive maintenance. Good Luck to ya!!! Oh yeah, use a Q-tip to clean the blade terminal on the coil. Put some di-electric grease in there after you clean it and then attach the new spring connector.
That "extra part" belongs on the underside of the engine cover (or whatever they call it); look at the underside of the cover you'll see the other three washers still in place.
I recently bought some Motorcraft OEM boots that did NOT come with new springs. When I posted the message here people said some boots DONT come with new springs and that it is perfectly fine to use the old ones.
Is it really life or death to use new springs?
