So here is a single post with the mods I did to the firewall:
Stock 1992 Firewall, minor cutting started
Stock 1992 Firewall, cut on all 4 sides, ready to remove.
Stock 1992 Firewall removed.
1997 Firewall welded into the 1992.
1997 Firewall Welding and Sealing completed. Also note the ECM Mount was added.
1997 Firwall completed, with 1997 Black Mastic Added
Black Mastic is place with Brake Pedal, and shift cable Mounted. Also added ECM ground Plate, and AirBag Module in Passenger Footwell.
Heater & A/C Plenum added.
E-brake Added.
Dash Mounted!
Steering Wheel Mounted
Center Console Mounted
Under Column Panel Mounted
Ryan
