It wasn't a recall, it was a "customer satisfaction program" and yes, the PCM reprogram is supposedly to prevent contamination of contacts.... Don't ask me how.... Its not me that made that claim, its Ford. From the letter Ford sent to 2011 owners:
"Customer Satisfaction Program 12B36
What is the issue? On your vehicle, contamination can build up on the internal electrical contacts of the engine cooling fan motors, causing the fans to be inoperative. Inoperative engine cooling fans could lead to high engine temperature gauge readings and reduced air conditioning performance. Continued operation of the vehicle could result in illumination of the Malfunction Indicator Light (MIL) and eventually cause the engine to automatically enter derate (reduced power) mode.
What will Ford and your dealer do? In the interest of customer satisfaction, FMC has authorized your dealer to inspect the operation of the engine cooling fans on your vehicle and replace them if necessary. In addition, your dealer will reprogram your vehicle's PCM to prevent contamination from accumulating in the future.
This service will be performed free of charge (Parts and labor) under the terms of this program.
This CSP will be in effect until May 1, 2013 regardless of mileage. Coverage is automatically transferred to subsequent owners.
What should you do? Please call your dealer without delay and request a service date for Customer Satisfaction Program 12B36. Prove your VIN.
Do you need a rental vehicle? If your dealer determines that the cooling fans on your vehicle require replacement, your dealer is authorized to provide a rental vehicle for your personal transportation at no charge while parts are on order. "
