Hey guys, still have no 4wd. No lights in the dash, even at key up,(checked both bulbs and they are good). All fuses and relays test out good. Still need to pull plugs off GEM to make sure it has a good ground and power. My 4wd switch is within spec and working properly. I'm thinking that its the GEM.
Does anyone know what else the GEM controls? Is it common to just loose the 4wd part of the GEM and nothing else? Because everything else in the truck works properly inside and out, just the 4wd.
Is the GEM a factory only part? About how much are they if anyone knows? Thanks for any help in advance.
Ben
Ben
