This is the way to train the system for new TPMS sensors for 2004
With this type of sensors
Turn the ignition switch to the OFF position.
Turn the ignition switch from the OFF position to the RUN position three times, ending in the RUN position. Do not wait more than one minute between each key cycle.
Press and release the brake pedal.
The horn will sound once and the TPMS indicator will flash if train mode has been entered successfully. If equipped, the message center displays "TRAIN LF TIRE", place the magnet on the valve stem of the LF tire pressure sensor. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the TPMS module.
Within two minutes after the horn sounds, place the magnet on the valve stem of the RF tire pressure sensor.
NOTE: If the VSM (TPMS module integral to VSM) does not recognize any one of the four tire pressure sensors during the tire training procedure, the horn will sound twice and the message center (if equipped) will display "TIRE NOT TRAINED REPEAT" and the procedure must be repeated.
Repeat Step 7 for the RR and LR tires.
When the tire training procedure is complete, the horn will sound once and the message center (if equipped) will display "TIRE TRAINING MODE COMPLETE"
for 2006 and above with this type of sensors
you need TPMS remote instead of the magnet
The horn will sound once and the TPMS indicator will flash if train mode has been entered successfully. If equipped, the message center displays "TRAIN LF TIRE", press the button on the remote (it will light) and pass it over the circumference of the rim in the opposite side of the valve stem of the LF tire pressure sensor. The horn will sound briefly to indicate that the tire pressure sensor has been recognized by the TPMS module.
Within two minutes after the horn sounds, press the button on the remote (it will light) and pass it over the circumference of the rim in the opposite side of the valve stem of the RF tire pressure sensor.
