thanna
- August 29, 2005
- Olando, FL
I have a 91 Ranger 2wd 4.0L with the A4LD. I pulled the transmission out due to 2 common problems. No OD and slow engagement in drive and reverse. The OD problem was easy, the apply stut for the OD band was broke. (Kind if a different twist on an old problem)
Before I started, I thought that I had a bad torque converter, but after reading some posts here, I am not sure. While removing the trans I found the vacumm line to the modulator unplugged. I replaced the modulator (may not have had to) and did a valve body Transgo kit upgrade and replaced the seals in the low/reverse servo.
My question is. Do I still need to replace the torque converter? I would rather not spend the money if that was not my problem. This truck is a daily commuter only, very rarely used for hauling.
