SCE2045
- April 30, 2021
- Fairbanks, Alaska
- 2002 4.6 4WD Limited
TL;DR: Smashed the Hitch while parking, don't tow anyway, disconnected it completely all the way down to the Trailer Brake(?) Now 4x4 doesn't engage
I've been looking around for the wire in Walmart, Autozone, O'reilly, Car quest, etc but they only have the small connector, there's nothing on the system for them to order plus they're clueless about it, so i just want to know what's the wire called like so I can order it, it sits under the rear bumper to the right. ABS is good, Control Module works, no problems in the transfer case whatsoever ever, only thing is Code U1900, that's it, but I disconnected fuse(after finding out 4x4 doesn't engage) 26 and there's no code anymore
Below is the cable that goes wherever it goes to the front, that's where you connect the trailer thing. One with the connector from Autozone and the other the wire itself
