tnmk
- May 6, 2006
- Kaukauna, WI
- '00 Mountaineer
I did the TPS mod (adjustment really, i wouldn't consider it a modification)
A little different on mine from what is on the post that I read.
I didn't have to remove anything to get to the TPS. Right infront of me, just needed a right angle screwdriver.
Wire colors were different (maybe cause it's a mercury?)
gray/red stripe = ground
gray/white stripe = signal
brown/white stripe = 5v reference
Didn't bother with trying to slot the holes. just drilled 1/64" over size and it got me (barely) to the perfect .96 volts. Started at .91 volts.
I wouldn't think you'd have to go anymore than 1/32" oversize on that hole to get your adjustment.
Seems to have better throttle response. could just be psychological though.
Thanks for the tip!
Thanks for the tip!
