Bobs2018ExplorerSport
- February 4, 2019
- Location
- USA
- Livermore, CA
- 2018 Explorer Sport 4WD
- Callsign
- KD6ANY
I wanted to do a simple transmission "drain & refill", on my 2018 Explorer Sport (3.5 dual-turbo, with 6F55 tow-package transmission), but I'm having trouble ascertaining just how much new fluid will actually be needed to refill it.
The service manual only states that, for a complete transmission "removal" and rebuild, it requires 6.5 quarts. It also says that if the "side cover" is removed, it takes 4.5 quarts. However, the owners manual, as well as the factory service manual (and AllData) shows the capacity as being "11 quarts" or "11.6 quarts", depending on which source you're looking at.
I guess I'm looking to hear from anyone who has actually done the simple "drain and fill" service on this same late-model transmission, and how many quarts it actually took them to refill it? As an example, I don't want to purchase 12 quarts, only to then find out that this procedure only required 4 quarts.
