Axial32
- July 18, 2008
- Zeeland, Michigan
- 1997 2dr. V8 Sport
OK.. So I'm working on a friends 1997 4dr. V8 Explorer.. She has a huge leak of transmission fluid.. as you pour the oil in it comes right back out... The leak is coming from the front of the transmission... as like it would be the front input seal. The problem we're having is dropping the transmission:thumbdwn:, We have everything undone except for two bellhousing bolts and the exhaust. The exhaust shouldn't be in the way for dropping the transmission but it's in the way for removing a couple bolts... They are the top most bolt on the passenger side and the other one is just above where the starter would be on the passenger side. Any tips or ways to get those bolts out??? Please help..
