Chuck Norris
- June 7, 2009
- Dallas, OR
- 95 xlt
It's been in the 90's here and I ran the a/c which works fine. I shut my stock '95 explorer off and when I went to restart it a few mins later it would turn over but then die shortly after. This continues untill I turn off the a/c. It then will stay running but at around 2-300 rpm... I usually have to keep one foot giving it enough gas to get it up to a normal idle speed and use the other foot to brake. It will eventually work itself out to where it will be up to a normal idle speed on its own. Any help would be appreciated. I've probed the IAC with a voltmeter and it's fine according to the manual's volt spec's and I also cleaned it out w/ some carb cleaner, and I tested the TPS which is working correctly and fluctuates the resistance according to the throttle position.
