kylecolb
- October 4, 2010
- Oshkosh, WI
- 2002 XLT
Well I got my bull bar in today and had a ton of trouble installing it. Here is what I wrote to the company and the pictures are below!!! I really like the durability of it, holds me if I stand on it (I'm 235 pounds and almost 6'4") and I like the design. I would buy another product from them, but there might be extra work involved!!!
I'm not going to say it's a crappy product from Hunter, they just need to be more precise.
The bull bar came today and I installed it. BUT it took over 2 hours to installFirst off, I went to put the hardware inside the frame to mount the brackets. This side went in smoothly. Then I went to install the passenger side, got the hardware inside the frame and then the bolts didn't line up with the holes on the frame. So I took this side out and undid driver side and tried to swap them. Same thing, the hardware didn't fit into the driver side either. So I had to go get a 7/16" circular file and file the hole bigger. After filing for a good 20 minutes trying to get the frame hole bigger I finally got the hardware to fit. (by the way, the hardware bolt frame, the rectangular piece that goes inside the frame, was too wide by about 1/16" to 3/16").
The auction said nothing about having to modify the plastic skirting under the bumper to get the bull bar braces to fit on. I had to cut 1" (could have been narrower but I did 1") wide slots for the braces to fit under the bumper.
Now that it is all done, I like the way it looks and think it would hold up through time. Item parts just were not precisely measured which gave me a huge headache. I got it all on and looks great.
