rblais
- January 25, 2005
- Utica, NY
- 2000 Mountaineer
Good morning everyone. Just replaced spark plugs in 2010 Mountaineer w/V8 and 59K miles. Bought the truck used at 33K. Pulled what I believe to be the original plugs and replaced with Motorcraft SP 509's; all but 7 of them anyway. When I got to the #6 cylinder there was (is) a different type of plug in it. There is no nut on this plug for the 9/16" plug socket to fit on, only what appears to be a smooth round metal ring below the ceramic as part of the plug itself. If I was seeing things correctly, there appeared to be red lettering on the white ceramic part of the plug. The 7 plugs that were removed have the normal blue Motorcraft lettering with the correct part number on them.
This engine does not have the shielded plugs that are so difficult to get out. The original plugs threaded out easily and the new ones went in easily with zinc antiseeze. Truck seems to be running fine after change out (with the old #6 plug left in place).
Does anyone out there have a clue as to what was found in the #6 hole?
Thanks in advance for any and all responses.
