malohnes
- August 8, 2009
- SE Alaska
- '91 xl m5 4x4
I mostly lurk and let the experts do the talking. I have found lots of help and info witht he handy search function here.However I have a problem that never goes away and it is bugging me.
Been working on my 91 trying to quiet down the classic knocking. Tune up helped: plugs, wires, cleaned MAS, throttle cable mod, seafoam, homemade CAI...but I'm still having troubles with the knocking. This was done about 2k miles ago. I have 130k miles on the clock and 1 head was replaced 3 years ago.
For clarification, the knocking occurs on load, warm engine, gears 3-5 but mostly on 4 & 5 on hills. It comes and goes, worse on warm summer days, better on cool winter days. Sometimes even a fresh tank of gas affects it. Right now using premium, third straight tank revealed a mostly quiet engine, but it is starting to knock again. Lucas fuel injector cleaner has been used and fresh oil change using Amsoil oil and filter was recently done. I pulled plugs and found 5 out of 6 with hard whiteish deposits that broke of nicely so the plugs were cleaned and reused. The 6th plug was tan with slight buildup.
So okay, I did a search and found a few threads refering to coil packs getting weak when replacing/freshening the above mentioned items in a tune up. I have not found any aftermarket coilpacks. Any recommendations?
