dtom29
- May 10, 2016
- 2003 Eddie Bauer Explorer
Where is the Vacuum reservior located on a 2003 Eddie Bauer Explorer with 4.0? A little backround, Vents will change at idle or when vacuum is highest during deceleration but will default to defrost during acceleration or normal driving which indicates a vaccum leak.
Also, what is the color code on the vacuum block under the dash, and what should be in the top port? I plugged the top port in the vacuum block under the dash but there is no loose hose hanging under there. I also have a problem with the driverside vents being warmer than the passanger side. I'll change the blend door actuator after solving the vacuum problem.
