smegun
- April 3, 2013
- florida
- 1994 ford explorer xlt
poor run time any one want to elaborate?
ive backprobed my cam sensor changed pcm's still the same poor run time ...it gets worse...a head job new rods lifters rockers gaskets poor run time still missing cleaned up my battery terminals on top of the engine and wondering if I should change the negative battery terminal
doesn't make sense anything I do has same poor firing symptom of course I changed the coil the ohms test is good
the waste spark system is dependent on what wiring? I feel I may have lost energy to ground what would or could be the next culprit as the drivers side bank /heads are suspect …. the coil seems dependant on the screws that mount the coil to the coil stand regarding impedance checking seems like I have spark just not able to tell how much
