Djsynystr
- June 21, 2008
- Bethlehem
- 1997 4 Door AWD
ok long story short. burnt out my 94 explorers trans when i started towing my 3500lb or less trailer around. i wasn't using propper towing practices due to never towing and just being a plan ol' dumbass. ie: driving with od on, going 80+ mph, passing alot, no trans temp gauge, no extra trans cooler you know being a DUMBASS! so now onto my post. since then i have purcashed a 97 XLT awd for $1200 in excellent condition. i had to do some minor maintance shocks, oil change, etc. i also added a 3rd trans cooler, (already had a small factor add on one in front of rad) temp gauge, class 3 hitch as well as adding a welded drain plug in my trans pan when i did a filter/fluid change this weekend to make fluid only changes easier. def a good idea if you can weld it yourself or take it to a shop to weld for a few bucks. now that i have all my coolers and a gauge i am noticing my temps. its odd to me but maybe its because im not sure what numbers i should see but when i drive without towing anything in OD with slight stop and go with long go's i get temps of about 175ish. this weekend i towed for the first time with the gauge and all the coolers the 1st day it didn't even go over 130 degrees (lowest on my gauge) then the next day it hit maybe 135 140ish towing the same trailer. is this normal to have lower temps when towing with od off doing slight stop go with alot of go's rather than not towing in od with same driving conditions? should i just be concerned with it getting "too hot" or is this change in temps showing signs of something else? forgive me for being a "newbie" but i can't afford to replace another vehical for a little bit so i have to keep this one in good shape. thanks in advance, any insight would be great!
