motogeezer
- September 9, 2013
- Location
- Central Maryland
- 1996 Aerostar Cargo
Just picked up a low mileage 96 Cargo. Thanks to Brooklynbay's instruction post, I changed out a broken slide door latch. Door will now latch, but needs
a hefty slam. I guess something still needs adjustment.
Along with the defective latch, I had the "Door Ajar" light on. I hoped the latch fix would cure the light too. Nope. I first cleaned the 4 contacts. No work.
I then popped out the pillar contacts, unplugged them, and jumper-ed the two wires. I could hear a relay in the dash actuate, and the "Door Ajar" light would
dim a bit, but wouldn't go off. I (with great difficulty) unplugged the relay under the dash, the relay stopped clicking, but light is still on. So....what else could cause the light to stay on?
Could any of the plunger switches in the front doors be the culprit?. I've pushed them in as far as I could to make sure they made contact. Still got the darn light. Is there any actuator in the rear barn doors?
So my door is still difficult to close, and my door ajar light won't go off. Any
guidance is greatly appreciated. Thanks
