- February 2, 2002
- 1998 Mountaineer AWD
The hose is probably clogged. Pull it off the radiator and blow it out.
There is only one component in your cooling system that adjusts pressure.
Ignore me. For some reason I was thinking pressure issue when your thread clearly state coolant lossAnd.......
If it has more than 175k on it you should rebuild it and upgrade it while you are at it!Ok, I can accept that it probably is a head gasket issue. I've tried a head gasket sealer in the past with marginal improvement.
So, the question is....Do I let this ride til the timing chain eventually craps out then just swap the motor? or Do I work on the head gasket (which means pay someone to work on the head gasket)
Other than this, she purrs like a kitten.
No, it doesn't overheat.
You’ve tried it on this motor? K Seal is supposed to be the best.
