Superrcharge
- October 31, 2015
- Elgin, S.C. 29045
- 1986 Ford Ranger
I have a 1997 Mazda 2300 pickup. The starter doesn't respond at all. It has a new starter on it and a new alternator also. All it does is click at the starter relay. I have traced a god bit of wiring out and cannot find a short as of yet. I am using a Power Probe tool called the Hook which is an excellent tool for this kind of work. The ignition switch and wiring seems to be all right. It has a start wire and a run wire plus a hot wire all the time when the ignition is in the off mode. I have found one fusible link and it is good. I know there is 2 more but haven't been able to locate them as far as the wiring schematic illustrates. Any suggestions appreciated. Thanks.
