MuscleJunkie
- April 14, 2007
- '00 Ford Explorer LTD AWD
So I think my transmission is toast.... I think - maybe someone here can tell me different?
So as everyone might know I just finished a major upgrade on my 5.0 AWD 2000 Limited Explorer which consisted of:
When vehicle is at a stop after driving - coming to a stop there is a swishing noise coming from the unit that I can hear. When I put it into neutral or drive - it goes away.
Anything I could be checking here that could save this 200k transmission or is it a goner?
If it is dead - obviously I am going to need a new unit. Suggestions? I really need something that is going to be bulletproof - performance OEM drivability (like if in 2000 Ford made an SVT level Explorer) that can handle the power I have now and will be adding in the future.
If I can answer anything else - just ask
Thanks in advance for any help or suggestion. Feeling frustrated.
- Powerdyne Supercharger with Bosch BOV
- 1" Intake Spacer
- 90MM MAF
- GT500 Injectors
- 75MM Throttle Body (kept stock TPS)
- 80MM Intake Elbow
- Electric Cooling Fan (Contour) and controller
- New Motor Mounts
- MSD Coils and new wires
- EGR Delete
- Already have headers installed
- Saleen Borla Cat Back
- Walboro 255LPH Fuel Pump
- Custom Tune (only fuel mapping - no transmission settings changed)
- With overdrive engaged, 4th to 3rd downshift was different (not normal)
- Engine would rev up then slam down into third
- manually turning off overdrive - transmission shifted as expected
- It was suggested this was related to tuning - that turned out to not be the case.
- Heater Core started leaking
- After a couple hundred miles - intermittent (which started to happen every time) chirping that sounded similar to belt squeal or camshaft syncro going bad
- Determined that noise was related to blown off PCV valve on back of intake
- This was resulting in vac leak.
- Apparently the stock PCV valve is not a one way valve and boost was causing it to blow off
- Replaced with Motorcraft EV-127-A for Thunderbird I think turbocoupe which is a one way valve and this problem is fully solved.
- After PCV was replaced - chirping was gone but now transmission is all screwed up
- When starting off sometimes it starts off in 2nd instead of 1st. This happens mostly after running awhile
- When the transmission is low 190s or 180s - seems to shift closer to normal but higher temps it really gets worse
- Slips out of gears when under heavy throttle intermittently.
- If driving really easy - less likely to see any slips except when starting out doesn't want to be in 1st when temps are hot.
- Fluid doesn't smell burnt - doesn't look bad
- Trans runs in the 200 range during normal driving now (outside temp 65 to 70)
- There is a trans cooler (i have stock trailer tow package and 3.73)
- Coolant is running during driving 180s to 190's during normal driving. Will go to 200 or so under heavy driving.
