porshapower
- September 30, 2005
- jacksonville Florida
- 1996 explorer
I am chasing a problem and am running out of ideas. I have no check engine light on but there is something not right. At idle the truck does not have a smooth idle. There is stumble (miss) in it. Its not severe and you cant even see it on the tach but you can here its slight popping out of the exhaust as its happening. I have replaced the plugs,Iac,egr valve,egr pressure sensor,cleaned the maf sensor,cleaned the throttle body,new airfilter. The truck accelerates perfectly and only stumbles at idle? Would spark plug wires cause a symptom like this? Also did the "seafoam" through the brake booster vaccum line. Ran techron fuel cleaner and tried different fuels. The explorer is a 5spd and I can see the shifter handle and feel it shaking from the non smooth idle. Wouldnt wires cause a misfire all the time even at acceleration? Thanks!Nel
