JoshT
- January 15, 2011
- Middle Georgia
- 1999 Ranger
Well I basically got the 5.0L AWD engine swap done on the 99 Ranger. Mostly good, got a recurring 02 sensor code. I don;t recall the codes for certain, but they were both for bank 2 sensor 1. Memory is telling me that one was for the heater circuit, the other was lean condition. It was over a week ago that I checked them and I've got a bigger problems that means I don't care about them.
Turns out that my good engine wasn't as good as I thought. With 10w-30 oil, my cold idle is 44 PSI, and when at operating temp I'm only running about 10 PSI per 1000 RPM. Will it survive? Yes, for a little while and I'm going to put in thicker oil to bandaid it for a bit. It ain;t right though and isn't going to stay that way for long if I can help it.
I do have another engine and it might be in better shape, but as far as I know both had 180k miles on them. I'm not taking a chance and will be rebuilding the spare engine before it goes in. Until I know more about the condition of the parts, the plan is to go with a stock style rebuild on the bottom end with a camshaft upgrade.
Not exactly sure what I'm going to do on the top end. I would like to stick with the GT-40P heads, both for style and since I already have the headers for them. I'm not chasing dyno numbers and I don't care about track times, just after a fun street truck that can serve as a daily driver. Not sure if these heads will do well enough to get that fun factor though.
My plan is to install a set of stock GT-40Ps with upgraded springs. I'll work on a DIY porting job on the other set of heads to swap in later. My concern is that either I'll damage the heads in the DIY porting attempt or will not be satisfied with the results.
I'm not entirely against going to aftermarket heads, but not in the budget for right now. Would the Torque Monster style headers work with aftermarket style heads, or is it going to make the plugs a PITA? Would the small 1.5" primaries and 2.25" collectors choke the aftermarket heads? If I need to get something different, is there something off the shelf that works with aftermarket heads and and the AWD chassis?
As I figure out more about what need and what I'm working with, I'll post more. Might start tearing the engine down in the next week, right now I'm trying to find a decent machine shop in my area, and possibly someone to do some porting work. For financial reasons I doubt I'll be using a porter for these heads, but I'm going to need to find one for a 2.3 head in the future, so might as well start looking.
