fuel pump relay...parts # | Ford Explorer Forums
93liftedXLT
left coast
92 xlt
92 ford explorer, can someone give me the parts number, for the fuel pump relay?
thanks
go to parts store, ask for 92 Explorer fuel pump relay.
Ford charges about $18+ for this, Autozone its $4.
Its just a relay with a special "head" on it so it will plug in.
There are basically two types of automtive relays, 4 prong and 5 prong, thats it.
Yeah i just bought one 6 bucks..lol
Hard to install or no? never changed one
under the fuse box on a 92 (pass side inner fender) pul out old relay, make sure contacts are clean, push in new relay.
pretty easy. :P
ill take a look right now, i thought it went in the fuse box.. guess not
i guess the autozone gave me the wrong on, cuss i looked behind the fuse box, under the hood, and i un clipped it fron the metal support brace, then pulled out the old reply, and the new one was the wrong size..
napa # AR240
There is a metal bracket between the Fuse block and fender. take a long bladed screwdriver and slightly pry it. The Fuse block is clipped into it. Look at it with a Flashlight you will see how the Fuse block snaps into it. You will have to do some wiggling.
__________________
Ok i cant get the box off the brackets... is there something i am missing? really pissing me off, i evan used a screw driver and um bolted it fron the fender.... :confused:
thanks
Can you see and understand how that bracket snaps the plastic box on? The first time I took mine off it was tough. I put a few dabs of grease on the Touch points. Hopefully it will be easier in the future.
I don't know what to say. I don't want you breaking anything but it can be stubborn
