- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Just what you people want to see! More of my truck, hahahaha
This is a great idea, a Bronco II registry for the best Ranger based vehicle forum on the intraweb, the Explorer4x4.com forum.
I need a place to keep track of all my modifications, trails I visit, bugs I work out, and idea's I have so this thread will be just that!
I hope to see more Bronco II owners taking the time to share pictures and modifications in here with their own threads as well. Many of the BII projects on this site are still under major construction, so in time I am sure this sub forum will grow. I know I like to see every BII that is still out there, these trucks have alot of potential and have always been considered "an underdog" but in my eyes its a legendary Ford Bronco and the best, most fun vehicle I have ever owned. People who doubt them just don't really understand them.
So here is my truck:
Started life:
1988 Ford Bronco II Eddie Bauer 4x4
2.9L EFI, Mitsubishi 5 speed, BW 1350 "touch drive" e shift transfer case, dana 28 ttb front suspension, corporate 7.5" rear axle, 3.55 gears, 10" rear drum brakes, cardigan style driveshafts front and rear.
A/C, power windows, cruise control, tire carrier, auto hubs, rear wiper/washer
the only two options my 88 BII did not have from the factory were glass sunroof and center console with message center.
When i got the truck it had faded paint, worn out "orange eddie bauer" interior and some serious driveability issues
Then:
Now-ish:
Drive train:
-1997 Ford small block 5.0L GT-40p engine (60K miles)
L&L solid engine mounts, Ford dual sump oil pan, Canton billet oil filter re-location adapter, Torque Monster Bronco II conversion headers, KKM intake with cold air induction. Ford 97 Mercury Mountaineer EEC-V computer (complete OBD-II conversion), 96 Mustang floor shifter with OD button.
-1997 4R70W automatic transmission
Modified Autofab urethane transmission mount
AOD output shaft and Advance Adapter AOD to BW1350 T case 5" adapter installed
-1993 BW 1354 E shift transfer case
-Custom explorer based drive shafts
Conversion thread on Explorerforum.com:
http://www.explorerforum.com/forums/showthread.php?t=124626
Front:
-Dana 35 TTB (Ford I beam) 4x4 front axle. Beams modified for 3" cut and turn, approx 1" track width increase per side. 4.10 Precision Gear ring and pinion with ARB air locker. Custom length outer axle shaft on passenger side, passenger beam modified for high clearance. Pass side axle shaft slip yoke is welded and fitted with a custom steel coil spring, C clip eliminated.
-James Duff early style 2" axle pivot drop brackets
-Skyjacker 6" lift coils
-Skyjacker extended radius arms (bushings) and transmission X member
-Superlift Superrunner steering system
-Timken wheel bearings, Moog ball joints, PF carbon metallic brake pads
-Warn manual hubs
-Rancho 9000 shocks
-Superlift 4" rubber brake lines
-Custom Ford sway bar and quick disconnect
Rear:
-Ford 8.8 31 spline disc brake explorer rear axle. Converted to spring over using weld on spring perches, custom shock mounts
-4.10 Yukon ring and pinion, ARB RD-81 air locker
-PF carbon metallic pads
-Skyjacker 4" Ranger leaf springs
-Superlift cast 2" tapered lift block
-Rancho 9000 shocks
Chasis:
-95 explorer brake master cylinder
-97 Explorer V8 Down pipes with factory catalytic converters w/ 4ea 02 sensors (OBD-II). Dual inlet single 3" outlet high flow muffler w/ 3" pipe over rear axle and straight out the back.
-Ron Davis custom "Nascar" aluminum 2 core radiator with fluid/fluid trans cooler (rad support modified for mounting)
-B&M transmission cooler
-1988 Bronco II fan shroud
-Modified BII gas tank and dual fuel pump system (OBD-II)
-BII transfer case and fuel tank skid plates, custom D35 diff skid plate
-James Duff receiver tube bumpers front and rear, PIAA driving light up front, billet license plate lights in back. Custom reverse light in rear bumper
-Hella H4 headlights
-Clear front parking lamps
-AutoFab fiberglass fenders
-Metallic blue paint
Interior (Ford "mocha"):
-90 Eddie Bauer (BII) door panels and headliner
-99 Eddie Bauer power/heated leather seats
-Husky front floor mats
-Painted dash, arm rests, trim, handles, etc to match mocha
-Custom white face BII gages,Autometer oil pressure, water temp, & trans temp 2-5/8" gages
-Garmin GPS, Radio shack CB, Tiger CB antennae
-Custom carpet, custom cargo liner and hold downs, custom center console, no back seat, custom racks for tools and supplies.
-97 explorer 2 way visors with lighted mirrors
Other:
-35x12.5 Mickey Thompson MTZ tires mounted on 15x10 black mods (wheeling)
-Dura Last gold battery
Stereo:
Kenwood Excelon Mp3 head unit, Music Keg, Alpine 5 channel, 13 speakers.
UNGO alarm
Custom modifications:
-Custom front fender liners
-LED side marker/parking lamps
-Many wiring modifications front to rear, integrated 94 power distribution)
Now instead of listing everything I have replaced/rebuilt or customized (sometimes more than once!!) I will list the things that are still OEM:
-Pass side power window motor
-Rear tailgate wiper motor
-Rear spare tire carrier
-Side mirrors
-"Touch Drive" pushbutton 4x4 console and computer
-Most of the body and glass
That’s it
next project:
body diet and full cage
Started life:
Then:
Now-ish:
Drive train:
Front:
-Warn manual hubs
-Rancho 9000 shocks
Rear:
-Rancho 9000 shocks
Chasis:
Other:
Stereo:
UNGO alarm
-Side mirrors
That’s it
next project:
