Serious Explorations Ford Explorer and Ranger Message Board
#1 Resource for Ford Explorers and Rangers for 20 years 1996-2016
Searches ExplorerForum.com Only
2017 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
How To: Replacing Front Hub / Bearing 1995+ Ford Explorer IFS
Reply
Thread Tools
Old 08-26-2006, 02:43 PM   #1
ncc
Manchester, NH
ncc's Avatar
'97 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Okay, continuing on my list of how-to's it's now time to change the front hub/bearing assemblies.
Work was peformed on a 1997 Eddie Bauer 4.0L SOHC 4x4.
I purchased a DynaPak hub assembly from Advance Auto for $177. Seems to be a solid unit and I've heard from people in the past that have not had any problems with them. They do have a one year warranty against defects.
You should also purchase a new axle nut. They're not that expensive and since you're going to waste a lot of lactic-acid getting it off, you may as well put a new shiny one in its place.
Tools you will need:
Jack
Jack stands
Lug nut wrench (should be with your jack in your vehicle)
1 1/4" socket OR
32mm socket
1/2" drive breaker bar
1/2" drive ratchet
3/8" ratchet
15mm socket
3/8" drive 3" extension
1/2" drive 3" or 6" extension
8mm wrench
Rubber mallet
Safety glasses
Long bar that will fit over your breaker bar's handle
Anti-Seize
Lok-Tite (blue tube)
*If you haven't noticed by reading my other how-to threads, I am an anti-seize whore. I believe in the stuff very strongly as I tend to hang on to my vehicles long enough to run into these repairs more than once. So it's a good way to plan ahead for the next time and you WILL thank yourself when that day finally comes.*
Hub Removal:
1. Loosen lug nuts
2. Loosen and remove axle nut with either 1 1/4" OR 32mm socket on a breaker bar. Try not to use your ratchet as you could damage it with the amount of force you'll need to get this nut off. You may need a long bar to put over your breaker bar for leverage.
3. Jack up vehicle and support it securely with jack stands.
4. Remove wheel.
5. Remove brake caliper. Two 15mm bolts hold this on.
6. Remove brake rotor. This just floats on the hub so a few good whacks with your rubber mallet should break it free.
7. Remove dust cover. Three 8mm bolts hold this on.
This is what you should now see:
8. Remove the 8mm bolt that holds the ABS Sensor wire to the back of the steering knuckle:
9. Disconnect the ABS Sensor wire quick-connect under the front bumper and any other clips securing this wire to the body:
10. Remove the three 15mm bolts holding the hub assembly to the steering knuckle:
11. Hit the lug side of the hub with your rubber mallet a few times; it should break free. Then it just slides off the axle splines and into your hands.
You should now see this:
Notice the huge amount of rust, fried grease and debris that was in the hub/bearing aperture.
12. Thoroughly clean and inspect the axle splines and hub/bearing aperture. Use a degreaser spray if necessary. Lay a film of anti-seize along the mating surfaces of the aperture and center flange of the axle.
13. Install new hub assembly by sliding unit onto axle splines and pushing back until it mates with the steering knuckle. Put some Lok-Tite on the axle threads and install the new axle-nut (just needs to be finger tight at this point). This will help hold the unit in place while you line up the three bolt holes and install the bolts.
Since this is a piece that usually does not come off the vehicle until it's time for replacement, I choose to Lok-Tite the three mounting bolts and then torque them down.
Tada! Pretty easy, wasn't it?
14. Connect ABS Sensor to connector. The DynaPak hub assembly comes with new retaining clips to hold the wire to the frame. This was a very nice feature of the unit. Simply pop out the old crappy clips and pop the new ones in.
15. Reinstall dust shield, rotor and caliper assembly. DON'T FORGET TO TORQUE THE CALIPER BOLTS DOWN TIGHT!!! These have a very bad habit of falling off on people.
16. Reinstall wheel and lug nuts (don't forget to anti-seize the lugs!) and lower the vehicle.
17. Perform final torquing of the lug nuts and axle nut (250ft/lbs).
That's it. You're done! No more God-awful rubbing noises announcing your presence wherever you go.
Jeremy
'97 Eddie Bauer 4.0L SOHC
ncc is offline   Reply With Quote
( Join the Elite Explorers )
Join the Elite Explorers for only $20 a year
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose and fix problems yourself, and learn which modifications really work without having to experiment on your own. Elite Explorer members can change the forum "styles" to eliminate most ads, including the blue underlined links, and no ads on photos. Other benefits include the ability to store 1000 Private Messages, add your own avatar to your posts, upload photo attachments directly to your posts and to our Photo Gallery and more. Join the Elite Explorers today. Your support of the forum is greatly appreciated.
Old 08-26-2006, 02:45 PM   #2
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 22 Post(s)
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline   Reply With Quote
Old 08-26-2006, 03:22 PM   #3
ExplorerDMB
Moderator/Technician
Mechanicsville, Virginia
2004 Acura TL
Vehicle Specs
Quoted: 0 Post(s)
Very good post!
__________________
My Useful Threads (38 Entries and Growing)
ExplorerDMB is offline   Reply With Quote
Old 08-26-2006, 03:28 PM   #4
ncc
Manchester, NH
ncc's Avatar
'97 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you. I've gotten a lot of help from this site since I bought my first Explorer last year so I thought I'd try and give something back with a few How-To's.
Jeremy
Old 08-26-2006, 04:20 PM   #5
jahomes
denver, Co
99 xlt
Vehicle Specs
Quoted: 0 Post(s)
My first post and I must admit this is pretty thorough. I will be ordering both from hubs this week and will install next weekend. I have seen some post here that directed you on doing this, but nothing like this. Thanks again!
jahomes is offline   Reply With Quote
Old 08-26-2006, 04:28 PM   #6
Ray Lobato
Moderator
Ray Lobato's Avatar
2006 Honda Accord
Vehicle Specs
Quoted: 1 Post(s)
Thumbs up
Jeremy,
Great thread! This is definately going into the Useful Threads Forum.
__________________
Happy Wheelin'
Ray L.
Ray Lobato is offline   Reply With Quote
Old 08-26-2006, 05:29 PM   #7
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL Pumpkin Edition
Vehicle Specs
Quoted: 425 Post(s)
Quote:
Jeremy
I appreciate that. I'll set you up with 3 months worth of Elite Explorer status for your efforts
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
1960 Dodge Dart Seneca
Rick is offline   Reply With Quote
Old 08-26-2006, 05:47 PM   #8
ncc
Manchester, NH
ncc's Avatar
'97 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey Rick, that's really nice of you, thanks!
Jeremy
__________________
January 2011: No longer an Explorer owner, sorry! Grand Cherokee owner since 2007....
How-To: Replacing Front Chassis Components
How-To: Replacing Front Hubs/Bearings
How-To: Replacing A/C Compressor
How-To: Replacing A/C Receiver Drier/Accumulator
Old 09-02-2006, 10:27 PM   #9
sport01mi
Woodhaven, MI
01 Sport
Vehicle Specs
Quoted: 0 Post(s)
Thanks man, this guide will come in handy when I go to do this job in the near future. Well written!
sport01mi is offline   Reply With Quote
Old 09-05-2006, 08:40 AM   #10
redskins13
Akron, PA
'95 Ford Explorer XLT 4.0
Vehicle Specs
Quoted: 0 Post(s)
I'm having trouble getting the assembly off that holds the calipers. I have them off, and the pads, but the bracket that holds the actual calipers has 4 bolts on the backside attaching it to the wheel assembly. I have a 95' XLT and the bolts are just un-movable. I have sprayed bolt loosener on them and have tried heating them but I can't get them off. I have a stud that I need to replace and it seems that the only way is by taking off this bracket so I can get the rotor off since it seems the rotor needs to come off (the hub is attached to it) in order to get at the studs. Does this make sense? Anybody know how to get these bolts off, or if they are reverse threaded or something, or if I'm doing the whole job wrong and there's a different/better way of doing it.
Thanks,
Greg
redskins13 is offline   Reply With Quote
Old 09-06-2006, 03:27 PM   #11
redskins13
Akron, PA
Vehicle Specs
Quoted: 0 Post(s)
bump....anyone?
Old 09-14-2006, 08:40 AM   #12
chrystal
essex uk
2000 North Face
Vehicle Specs
Quoted: 1 Post(s)
Excellent - I have just done this job following these instructions. The only thing I found was that to undo the 3 nuts holding the hub on I had to use a 15mm spanner as my socket wouldnt fit due to the axle housing. Plus I used a 24" breaker bar and the hub nut came off easily. The hardest nuts to undo were the hub nuts on the steering assembly.
Once again - Thanks
__________________
In the UK petrol IS a mod
89p for a litre - $1.6!!! wow how lucky I was then now 92-96p a litre $1.87-$1.95 or $7.80 a gallon!!!!!!- now 1.10 a litre and rising....$8+ a gallon!!!!
Can I put a 1L engine in? Now 1.38 a Litre - Driving an Ex now a luxury pursuit only!
chrystal is offline   Reply With Quote
Old 09-18-2006, 02:06 PM   #13
DominicanX
Fairfax, Virginia
99 Sport
Vehicle Specs
Quoted: 8 Post(s)
Awesome Write up you just saved me $900!!!!!!!!!
DominicanX is offline   Reply With Quote
Old 11-09-2006, 03:17 PM   #14
flyncasafo
Syracuse, NY
flyncasafo's Avatar
'00 EB
Vehicle Specs
Quoted: 0 Post(s)
Excellent post! Wish I had found this a year ago to save my broke butt money. Excellent Web Site also.
flyncasafo is offline   Reply With Quote
Old 12-21-2006, 12:45 PM   #15
dkchrist
Fayetteville, AR
93 XLT 4DR
Vehicle Specs
Quoted: 14 Post(s)
nice write up this is one of the thing I need to do in the near future
dkchrist is offline   Reply With Quote
Old 01-03-2007, 01:51 PM   #16
Big6ft6
Madison, WI
1997 5.0 AWD
Vehicle Specs
Quoted: 0 Post(s)
I wish I would've read this thread 24hrs ago, I just signed the paper to pay my mechanic $500 to do this 01 Limited. They said the part alone was $345 I assumed that becuase there was a drive shaft in there that repalcing the bearing would be a big deal...AAAaarrrh. this makes me agry
I look forward to spending more time on this site before I take my explorer in next time.
keep up the good work
Big6ft6 is offline   Reply With Quote
Old 01-24-2007, 11:04 AM   #17
Ranger Al
Fresno, California
'00 FX4 Ranger
Vehicle Specs
Quoted: 0 Post(s)
When I did mine, I bought the bearing assembly from Pep Boys with Lifetime warranty. The bearing assembly was made by Timken the same company that Ford uses. Maybe a good idea to spend a few extra bucks for peace of mine....
__________________
1. XLT Ranger 4dr 4.0 5 spd 4X4-> K&N filter, grill insert, Stainless steel skid plate, 98 Mountaineer front axles swap, factory motor transplanted and new clutch kit, 3" Flowmaster 40 dual outlet, hard bedcover, JamesDuff traction bars, Bilstien shocks.
2. 1999 K1200RS BMW motorcycle <fast German technology>
3. 2005 Suzuki XL 7, the only small SUV with 7 passengers I could effort under $15K
4. 1970 VW project -needs exhaust, interior, extrical parts..
Ranger Al is offline   Reply With Quote
Old 02-23-2007, 10:44 PM   #18
daffy
Peoria, Il
'00 EB 4x4 4.0 SOHC
Vehicle Specs
Quoted: 1 Post(s)
Well, I finally got around to doing my right side tonight, this is a great write-up.
Took me about 2 hours, not in a rush. I must admit, either my torque wrench is off, or I'm stronger than I think, 215 Lb/ft didn't seem to be as much effort as I expected. I didn't even need a cheater on my 3' breaker to get the other one off.
Just to add a bit of help to those who might try this, the nut you should replace is Ford part # N808985-S100 (Nut and washer) Cost me $16 with tax (ouch).
I looked at the online places, they were all back ordered, of Autozone, O'Riely's, Advance, nobody had it listed, or they would give me the wrong one.
Also I used the Timken hub from Autozone, #242591 $154, best price I've seen for these hubs.
To those that have done this, is it me, or does that nut seem a little smaller than 32mm? My socket seemed loose, on both the one I took off, and the new one.
Anyways, I'm bummed, I think I have to do the left too, my front end growling got quieter, but not quiet enough.
daffy is offline   Reply With Quote
Old 02-24-2007, 11:46 PM   #19
docnpat@hotmail.
01 sport
Vehicle Specs
Quoted: 0 Post(s)
Same process for 2001?
Is the process the same for the 2001? Any major differences?
docnpat@hotmail. is offline   Reply With Quote
Old 02-25-2007, 06:48 PM   #20
01 Black Sport
Sudbury
01 sport
Vehicle Specs
Quoted: 0 Post(s)
Yes id also like to know if its the same for a 2001 sport. I think it might be a one piece hub with the brake disc also though????
01 Black Sport is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Copyright 2016 - 1996 Rick Horwitz Photography Explorer Forum is celebrating it's 20th birthday!!
Ford Motor Company is not involved in the management of this site in any way.
