**EMERGENCY** Torsion bar help needed! | Ford Explorer Forums
Walnut777
South Carolina
96 XLT
Hey guys. I had to put a lower control arm on today b/c my lower balljoint that I just put on last month was sliding up and down with ease.
I marked the nut that lowers and raises the torsion bar.
I took everything loose from the lower control arm and then slid the lower control arm off of the torsion bar.
I put the torsion bar back in the lower control arm the same way I thought I took it out and now I cant even get my jack out from under that side of the truck!
There is another piece under the drivers seat that the torsion bar slides into and the adjuster screw raises up and down, well it is loose, what can I do? Or what did I do wrong?
Sounds like your a hex off. you have to losten the adjuster and then put it on and readjust the adjuster
Look at the front of the torsion bar, there are letters on it and a L/R marking. Those letters should be upright when the LCA is installed. Place the bar in the control arm so that those letters are legible with the arm level. Any other clocking of the bar will not install properly.
The LCA should be installed with it at a downward angle to the ground of say 45 degrees. In that position the rear of the torsion bar will be near to where it sets in the rear mount. Leave the adjuster bolt out or almost out of its cross bar. Place the bar in there properly, with the LCA angled down, then raise the LCA up into place. Using the floor jack under the LCA works well to get the UCA into the spindle. Good luck,
Thanks! Got it finished this morning. I had to take my son to his baseball game yesterday evening and it was too dark when I got home.
Thanks again!!
good write up. thanks.
