XL-rated tires: Normal driving vs. Towing | Ford Explorer Forums - Serious Explorations
Just got new tires on the Mounty (235/65-18).
Had it narrowed it down to these, within a few dollars of each other with rebates:
a. Pirelli Scorpion Verde All-Season Plus (106H SL)
b. Yokohama YK-HTX (110T XL)
Since I tow a 5200 lbs camper, the salesguy recommended the XL rated Yokohama. I left with the tires at 36psi (as I usually do). First pull with the trailer, things felt a bit loose. Then I noticed the XL tires get their max rating at 50psi. I didn't think it would matter, since my previous BFG LongTrails (SL tires) were very secure at 36psi.
So, what do people do with XL or LT rated tires? Do you keep them at 36 for normal driving, then pump them up when towing (or hauling a load)? Or do you keep them at the higher pressure all the time? When towing, do I take it all the way to 50 psi? That's what you are supposed to do with ST trailer tires. But what about these XL-rated passenger tires?
PS - The door sticker on the Mounty calls for only 32psi. I've always just used 36.
I run floatation tires. Their max weight rating is calculated at 50 psi. I run them at 50 psi all of the time but with all my off road mods, ride isn't a concern.
