1989dangeroustoy
- October 27, 2011
- redlands, California
- 1996 ford explorer
I have a 96 explorer 4.0 ohv, today I did a compression test and got about 90 psi on all cylinders, I don't know if its bad rings, valves or timing chain, also I think I may have a cracked head, what do you guys think? Also do you think I'd be better off buying a used motor or rebuilding mine, I'd rather not pull the motor out and I definitely do not want to rebuild the bottom end
