Afboy143
- September 23, 2003
- Tampa,FL
- 1999 Ford Explorer Sport
http://cgi.ebay.com/ebaymotors/ws/e...&item=7944360887&rd=1&sspagename=STRK:MEWN:IT
Works great! The adapter however came in a black finish unlike the silver shown in the pictures. The adapter was very clean cut, no rough edges. The adapter was a bit larger than the MAS. I also had to open the holes up wider towards the inside in order for the adapter to fit since it was off. The adapter is made out of aluminum so it was hard at all. After making the holes bigger, I found bolts that were laying around since it didnt come with any and made a metal mount and tapconned it to the front side of the truck. I then mounted the filter on the adapter and turned the explorer on. Started rite up. I took it out for a drive and it gets a bit louder when I gun it as compared to when I had the air box. It also is a lot more jumpy at stops. Best 23$ I ever spent! If you dont mind modding a bit to make it fit, I reccomend this.
Now I cant wait til this weekend til I get my dual 50 series flow masters installed
Pics of how it came out follows tomarrow
