Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Ford 4R55E Transmission removal & installation instructions.
Reply
Thread Tools
Old 01-28-2005, 07:21 AM   #1
nozzleram
North Central Indiana
92 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Removal of 4R55E
Similar to a4ld minus some electronic connectors
4x4
1.Disconnect the negative battery cable.
2.Remove two bolts retaining the fan shroud to the radiator. Remove the transmission fluid level indicator.
3.Raise the vehicle and position suitable safety stands.
4.Remove four skid plate bolts and the skid plate.
5.Mark the relationship of the driveshaft centering flanges, rear axle companion flange, and transfer case flange so the driveshaft can be installed in the original position.
6.Remove four bolts retaining the driveshaft centering flange to the rear axle companion flange. Remove four bolts retaining the driveshaft centering flange at the transfer case flange. Remove the rear driveshaft.
7.Mark the front driveshaft at the transfer case yoke and U-joint flange. Remove four bolts retaining the front driveshaft at the transfer case yoke and at the U-joint flange. Remove the front driveshaft.
8.Remove the bolts and nuts from the catalytic converter outlet and muffler inlet. Using mechanics wire, secure the muffler and tailpipe assembly to the vehicle. Remove three nuts from the crossover-to-converter inlet and disconnect the HO2S connector. Disconnect the converter from the hanger and remove it from the vehicle.
9.Disconnect the shift cable from the lever and bracket. Position the cable aside. Disconnect two rear HO2S connectors and the locator.
10.Remove four bolts from the crossover pipe and remove the crossover.
11.Position a drain pan. Disconnect the heat shield from the transmission pan. Remove the transmission pan bolts and drain the transmission. Position the transmission pan and install the bolts, using the original gasket. Connect the heat shield to the pan and remove the drain pan.
12.Remove the ground wire nut at the starter motor and position the wire aside. Remove the starter stud and bolt. Position the starter aside.
13.NOTE: Flexplate-to-converter nuts are not reusable.
Mark the relationship of a converter stud to the flexplate. Rotate the torque converter and remove four flexplate-to-converter nuts. Discard the nuts.
14.Remove one upper right bell housing bolt and the fluid level indicator tube.
15.Disconnect the transmission cooler lines and install protective caps on the lines.
16.Disconnect the vehicle speed (VSS) sensor connector. Remove the nut and the vehicle speed (VSS) sensor. Disconnect the transfer case vent tube hose and the shift motor connector.
17.Position a jack stand to support the engine.
18.Position a transmission jack, raise it to the transmission, and secure it with a safety chain.
19.Remove the left and right crossmember bolts and nuts. Remove the transmission mount nuts. Remove the crossmember and slightly lower the transmission.
20.Disconnect both transmission 16-pin connectors at the rear of the left and right cylinder heads. Remove the transmission-to-engine bolts.
21.CAUTION:The torque converter must separate from the flexplate and remain seated in the transmission. The transmission must not tip forward, as the torque converter could fall out while lowering the transmission.
Separate the transmission from the engine and carefully lower the transmission from the vehicle.
nozzleram is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-28-2005, 08:29 AM   #2
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
Sure! First thing we need to know is 5 speed or automatic?
I assume automatic because well one's dead.
Do you have the Hayes or Chiltons repair manual?
Great place to start.
Do you have tools?
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 01-28-2005, 08:47 AM   #3
nozzleram
92 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Sorry, it's an Auto. I've got tools and some basic know how but I'm no mechanic. I'm heading out right now to pick up the Eddie Bauer that I'll be putting the good tranny into.
Old 01-28-2005, 09:39 AM   #4
Heavymentill
Ann Arbor, Michigan
Heavymentill's Avatar
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Removal of 4R55E
4x4
8.Remove the bolts and nuts from the catalytic converter outlet and muffler inlet. Using mechanics wire, secure the muffler and tailpipe assembly to the vehicle. Remove three nuts from the crossover-to-converter inlet and discoonect the HO2S connector. Disconnect the converter from the hanger and remove it from the vehicle.
16.Disconnect the vehicle speed (VSS) sensor connector. Remove the nut and the vehicle speed (VSS) sensor. Disconnect the transer case vent tube hose and the shift motor connector.
21.CAUTION:The torque converter must separate fromt he flexplate and remain seated in the transmission. The transmission must not tip forward, as the torque converter could fall out while lowering the transmission.
__________________
Heavymentill is offline   Reply With Quote
Old 02-25-2008, 08:36 PM   #5
Lefy
Westchester, NY
Lefy's Avatar
98 Sport 4x4 4.0 SOHC
Vehicle Specs
Quoted: 0 Post(s)
real good list thanks
__________________
Aussie Aussie Aussie Ohy Ohy Ohy
My Rig
Lefy is offline   Reply With Quote
Old 03-19-2009, 09:34 PM   #6
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 426 Post(s)
Thanks for printing this list of instructions! People constantly ask how to remove & install transmissions. I've renamed, and moved this thread to the transmission section. I'll make it a sticky thread for a while, but it should have a step by step procedure with pictures for people that have a hard time visualizing written text when they have never done this before.
BrooklynBay is offline   Reply With Quote
Old 05-07-2009, 01:06 AM   #7
screwd_newfie
edmonton,ab
91 xlt explorer
Vehicle Specs
Quoted: 0 Post(s)
that helps me out to lol.i got my tranny most of the way back in but it wont go that kast little click,im ready to burn the dam thing. a weekend job turns into a 2 week job and it being my daily driver doesnt help.but thanks for posting that thread.
screwd_newfie is offline   Reply With Quote
Old 05-07-2009, 01:10 AM   #8
nitro71
Spokane WA
Vehicle Specs
Quoted: 0 Post(s)
Factory repair manual! Chilton and Hanynes are good for starting fires..
nitro71 is offline   Reply With Quote
Old 05-12-2009, 05:50 PM   #9
paWOLFck
Raleigh, NC
paWOLFck's Avatar
'98 XLT 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
Haha. Yea got to get that digital Ford Shop Service manual.
I have a quick question though. I am doing the Timing Chain repair and we almost have the engine out just have to finish disconnecting the tranny. What is the best way to get to the top two Transmission to Engine bolts?
Thanks.
__________________
1998 XLT
4.0L SOHC - 3.73 LS - 33x12.5 Duratracs - 3" Body + TT/Warrior - 50" Curved Roof LED - 2x Hella 500FF HID swap - General Badassery
paWOLFck is offline   Reply With Quote
Old 05-12-2009, 08:53 PM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 426 Post(s)
Get a long extension (possibly even a wobble extension), and sockets with universals connected to them (one piece socket/U joint design).
Old 05-12-2009, 09:15 PM   #11
paWOLFck
Raleigh, NC
paWOLFck's Avatar
'98 XLT 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
K. I'll give it a try. My brother was trying to get them while I was at football so we'll see what we can do tomorrow.
Thanks.
Edit: Would it just be easier to pull the transmission and engine out together? It's an automatic by the way.
__________________
1998 XLT
Old 05-12-2009, 09:49 PM   #12
paWOLFck
Raleigh, NC
paWOLFck's Avatar
'98 XLT 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
Wow. Didn't mean to make new post. Sorry.
__________________
1998 XLT
Old 05-12-2009, 09:54 PM   #13
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 426 Post(s)
This will be hard to do without a lift, and a special engine crane. You might need a gantry crane since it will be heavy. I once broke an engine crane lifting a 3.0L without the transmission connected to it.
Old 05-12-2009, 10:09 PM   #14
paWOLFck
Raleigh, NC
paWOLFck's Avatar
'98 XLT 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
I want to leave it in. We are using a 2 ton Engine Hoist to lift it.
... How did you break a hoist with just the 3.0L being hoisted?
__________________
1998 XLT
Old 05-12-2009, 10:17 PM   #15
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 426 Post(s)
I was jacking it up, and the piston was struggling, then the piston broke. I bought another piston, and tried again, then it was still struggling until the boom, and another part started to bend. I had a machine shop put the boom into a hydraulic press to straighten it out, but I was still having problems. I ended up lifting the body to remove the engine, and transmission. I was able to move the engine & transmission myself so I can't understand why this tool didn't work. Another strange thing. It was my old 89 Mercury Sable. Since it's a front wheel drive, the engine has to be supported with a special hanger. The hanger also got bent, and wasn't usable. It seems like they are making tools out of butter instead of steel.
Old 05-13-2009, 04:28 PM   #16
Heavymentill
Ann Arbor, Michigan
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
In the past I have used a 3 foot extension with a U-joint. I have also used a combination wrench through the wheel wells with the wheels off. Also you will have no problem pulling the engine with a picker. Usually front wheel drive vehicles with inverse engines the engine needs to come out the under side.
__________________
Old 05-15-2009, 08:33 PM   #17
paWOLFck
Raleigh, NC
paWOLFck's Avatar
'98 XLT 4.0L SOHC
Vehicle Specs
Quoted: 1 Post(s)
Yea. We were able to get to both of them at the top. I'm going to get a combination wrench tomorrow to get them loose though. Thanks for the Help.
__________________
1998 XLT
Old 08-04-2009, 10:54 PM   #18
salo
winnipeg, MB
95 RANGER XL
Vehicle Specs
Quoted: 0 Post(s)
when i pull the tranny is it ok to remove the torque converter and drain it?
salo is offline   Reply With Quote
Old 08-05-2009, 12:00 AM   #19
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 426 Post(s)
You have to remove the torque converter anyway since it's better not to reuse an old one. It has dirty fluid in it.
Old 08-05-2009, 12:01 AM   #20
Mpetronek
Sandy, OR
'91 4.0L XLT 5spd.
Vehicle Specs
Quoted: 0 Post(s)
yeah i agree with the burning instruction manuals...they cause more work than do good.
__________________
'91 XLT 4x4 5spd Manual: 4.0L V6 OHV-Cat back 2.25 Dynomax single exhaust w/ Magnaflow tip, Cold air intake, Interior/ Exterior lighting including hyperwhite Headlights.
Mpetronek is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
FORD Transmission DTC - Diagnostic Trouble Codes. OBDII P0700-P0790. dallasmef Explorer & Ranger Transmissions, Transfer Cases, & Differentials 12 05-26-2011 08:56 PM
Stock 1/4 mile and 0-60 times for almost all cars in production CHEESYPOOFS Need for Speed! 41 06-30-2009 07:10 PM
Ohio Dept. of Education and Ford Motor Company Fund Join Forces on Education Program chriswells78 Auto Industry News 0 06-08-2006 12:56 PM
Bill Ford is here to stay Stephen Auto Industry News 9 12-12-2002 11:41 AM
Discrimination at FoMoCo? Stephen Auto Industry News 0 07-05-2001 04:30 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
