Gcrop
- January 3, 2005
- Memphis, Tennessee
- 2011 Explorer Limited
Well thanks to Brain, I found out that I had a torn valve body gasket when I opened up the tranny a few weeks ago to originally clean out the solenoids. It had the usual 2-3 shift issue AND it was slipping in 1st about 50% of the time. After cleaning the solenoids a few weeks ago it helped the slipping 1st gear down to only about 5-10% of the time. 2-3 shift issue was still there.
So on to today when I had the two new gaskets from Ford ($16 for both). I also went ahead and bought a new filter and pan gasket even though I had just put new ones on a few weeks ago. First of all I should have put a drain plug in last time but oh well. Everything actually went pretty smoothly other than the fact that I should have definitely kept better track of where all 20 or so bolts went to on the valve body. I actually had two tears in the "upper" gasket, the one between the seperator plate and the tranny. one tear on the side of the gasket right above the 4 solenoids. The other tear was on the corner of the reverse servo(??). I went ahead and "cleaned" the solenoids again while they were out.
After putting it all back together, my dad and I filled it up with 4 qts. and cranked it up (with the garage door open of course). Let it run for a few minutes and then tried to pull it out of the garage in Reverse. Nothing happened. The engine didn't bog down or anything. After I crapped my pants real quick, I put it in Drive. Again, nothing happened. Crapped my pants again while thinking that I forgot to reconnect something or left something out. I wasn't happy. So I then just shifted between all of the gears a few times and then dropped it in Reverse. It didn't move for about 3-5 seconds then dropped into gear finally. Long story short, it did that with all of the gears and even slipped a few times while I drove it around the block. After I few laps around the block I finally got Drive to work properly and WITHOUT THE 2-3 SHIFT PROBLEM!!! Even after it was running a lot better I was still nervous. Mainly b/c Reverse still wasn't shifting into Reverse as soon as I put it there. It has gotten better but still not perfect or even like it was before today. Hopefully tomorrow's driving will help it.
My big/main question to Brain/Glacier/whoever else after today:
Does it take a while to get the fluid to circulate throughout the valve body, are there airpockets that need to purge themselves out? It has taken a while but it seems like it is driving better the more I drive it. I didn't finish till 8:30 tonight and it is now 10:30PM so hopefully the drive to work tomorrow will help purge the system.
Thanks for any comments/suggestions/answers anyone might have,
Geoff
Geoff
