Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
The controversial question of when to change the fluid in the 5R55E automatic trans
Reply
Thread Tools
Old 07-18-2005, 12:29 PM   #1
BigE
Virginia
2000 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The controversial question of when to change the fluid in the 5R55E automatic transmission – have done much research & thought I would share what I found – not an endorsement of what maintenance plan to follow
Changing the fluid in the 5R55E (5 speed automatic) transmission used in the 2000 Explorer and some earlier and later years.
The maintenance manual that comes with the Explorer says change transmission fluid at 30K intervals for 5 models of transmissions (AX4S, AX4N, 4R70W, 4R100, 4F27E). The 5R55E transmission is not referenced. The manual repeats this maintenance schedule at 30K intervals until 150K, at which point it just says change the fluid and filter with no transmission model reference. The manual is not at all helpful trying to figure out what the recommended fluid change interval is. So I called Ford.
Ford customer service does not know what the “factory” recommended interval is!!! I asked for the phone number of someone who could help, they said there was nobody at Ford that could help. Their response was they did not have that information, and told me to call a dealer (that the dealer had access to information that the Ford company customer service representatives did not have access to).
So I called 5 dealers, locally to get the answer, with not a lot of luck. Finally, on the 5th try I got referred to a service manager who took the time to check his online access to Ford information. Meantime I found the service information in the factory service manual. His answer from his Ford reference, which also matches what the Ford service manual says, says that no fluid change is recommended or required when operating under non “special operating conditions” as defined by Ford in the operators manual. So Ford says fluid is there for the life of the transmission. The knowledgeable dealer said that met the Ford warranty requirements, including extended warranties.
So to change it at 30K or some other interval or wait until the transmission dies!!! And to complicate things, in my research for the answer on the internet, I heard people talking about changing their fluid at 30K or less intervals and still having the transmission fail with low mileage, while a few others talked about never changing their fluid and getting high mileage out of their transmission without a problem.
All of the dealers I spoke to that recommended changing the fluid at 30K, only recommended a flush (they did not recommend or include the pan drop and filter replace). They all said the flush process they used flushed the fluid in reverse, thus cleaned the filter. At least one of them said that even though the filter is enclosed in plastic, it was not a paper filter, e.g. it was a screen that could be cleaned by the back flow flush [anybody ever take one apart, e.g. is the factory filter a screen or paper filter?].
BigE is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-18-2005, 12:41 PM   #2
Ford_Racing_Guy
Spencer, Wisconsin
'92 XLT & '98 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
I myself try to stick to the Intervals that Purolator suggests.
they say to change the Transmission filter every 12,000 to 15,000 miles which then in turn you are adding at least 4 quarts of fresh fluid everytime.
__________________
1998 XLT
98 F250 XLT L/D
97 Ford Thunderbird LX
06 Yamaha R1
Ford_Racing_Guy is offline   Reply With Quote
Old 07-18-2005, 12:42 PM   #3
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
I sincerely hope that you didn't buy that about never changing a filter.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 07-18-2005, 12:53 PM   #4
davidmmm69
1995 2wd 4dr explorer Fall River Ma...
2002 XLT Explorer 4WD
Vehicle Specs
Quoted: 1 Post(s)
I jsut had my 2002 flushed and I am happy with what they did..
__________________
1995 Explorer 2WD on 33"BFG Muds 7" lift...
2002 Explorer Sport 4X4 255/75/16
davidmmm69 is offline   Reply With Quote
Old 07-18-2005, 12:53 PM   #5
mynameisaric
Bolingbrook, IL
mynameisaric's Avatar
98 XLT
Vehicle Specs
Quoted: 4 Post(s)
<---125,000 miles and i've never touched the transmission. not that i beleive i should never change it, but i dont know anything about trannies, and i'm too lazy to look it up. and i refuse to pay someone to do something that i could do. theres no slippage or clunking. it rides very smoothe still.
__________________
Web wheeler
-98 SAS Explorer
-05 F150 Supercab
mynameisaric is offline   Reply With Quote
Old 07-18-2005, 12:54 PM   #6
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
That is excessive in my opinion.
__________________
Al Franklin
My truck
My Quest for 30
Old 07-18-2005, 12:56 PM   #7
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Its called preventative maintenance for a reason.
__________________
Al Franklin
My truck
My Quest for 30
Old 07-18-2005, 12:58 PM   #8
davidmmm69
Vehicle Specs
Quoted: 1 Post(s)
My brothers van has 137000 on it and he never touched it as of yet. crazy i think..
I change all my 3 vehicles tansmission fluids once every 12000 miles.
very little price for the comfort of knowing it has fresh fluid in it,
as far as my 1995 with close to 170000 on it i change it every 6 months.
__________________
Old 07-18-2005, 04:49 PM   #9
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Why?
__________________
Al Franklin
My truck
My Quest for 30
Old 07-18-2005, 04:54 PM   #10
davidmmm69
Vehicle Specs
Quoted: 1 Post(s)
Why not??
__________________
Old 07-18-2005, 05:00 PM   #11
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Why not??
Several good reasons:
(1) its expensive
(2) its not needed
__________________
Al Franklin
My truck
My Quest for 30
Old 07-18-2005, 06:36 PM   #12
davidmmm69
Vehicle Specs
Quoted: 1 Post(s)
not expensive at all.. half dozen quarts of oil.
Fresh oil in a oil used, beat up, high mileage, transmission is nice insurance for me..
__________________
Old 07-18-2005, 08:33 PM   #13
OZexplore
coffs harbour n.s.w. Australia
98xlt
Vehicle Specs
Quoted: 0 Post(s)
in australia i read a book that goes to mechanics that lists all makes& models ever sold here(all specs) ,it says every 100,000 klm(60,000) local auto transmission experts reccomend every 20,000klm
now looking at it logically if a company reccomends oil changes 5 times as often as the booklet maybe it is just for financial advantage think about it 5 times the amount of oil ,filters,service charges etc @ $200 a time
i have always found the best place to get advice is from someone that knows what they are talking about but gain no financial advantage these people are not always easy to find
by the way i get mine done every 50,000 klm
OZexplore is offline   Reply With Quote
Old 07-18-2005, 08:41 PM   #14
davidmmm69
Vehicle Specs
Quoted: 1 Post(s)
Most of it is how you feel and your personal preference.
just like many people i know every 3000 miles they are changing fluids.
not everyone can feel good with leaving certain fluids in the car for that long of a time.
and god forbid something bad happens to engine or transmission. you will be like my god why didn;t i do that mmuch sooner..
__________________
Old 07-18-2005, 10:24 PM   #15
Ford_Racing_Guy
Spencer, Wisconsin
Vehicle Specs
Quoted: 0 Post(s)
i myself was planning to add an external filter so i wouldn't have to drop the pan as often as i have been.
__________________
1998 XLT
98 F250 XLT L/D
06 Yamaha R1
Old 07-19-2005, 07:20 AM   #16
davidmmm69
Vehicle Specs
Quoted: 1 Post(s)
i put a drain plug in so when i do it. in 6 months it is just a fluid swap than at 12 months the filter is changed also..
n
i
eve put a drain plug in my wifes van which makes it so easy to drain...
__________________
Old 07-19-2005, 07:42 AM   #17
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
n
i
So you are just changing about 4 quarts? Not a complete chanfe.
__________________
Al Franklin
My truck
My Quest for 30
Old 07-19-2005, 09:47 AM   #18
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 3 Post(s)
You just answered your own question.
You think Ford doesnt know when the fluid and filter should be changed?
This is the MINIMUM required PREVENATIVE maintenence....
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 07-19-2005, 12:04 PM   #19
mynameisaric
Bolingbrook, IL
98 XLT
Vehicle Specs
Quoted: 4 Post(s)
i've run across alot of stories where ppl change there fluid and there trans goes out a few thousand miles later, and some where they never change it and there over 200,000. and theres also ppl that go through 3 transmissions before 100,000 miles. how hard is it to change a transmission filter? ( to be honest i didnt know a transmission had a filter) and change the fluid? i havent worked on my truck since i made the bumper, so i need something to do to it.
__________________
Web wheeler
-98 SAS Explorer
-05 F150 Supercab
Old 07-19-2005, 12:13 PM   #20
davidmmm69
Vehicle Specs
Quoted: 1 Post(s)
Quote:
6 months I change the fluid that comes out via the pan.
at 12 months i do a change and also filter change...
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
