#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Replacing Thermostat
Reply
Thread Tools
Old 01-05-2000, 12:19 AM   #1
NoBoundaries
Moderator
ECX Member
Ellicott City, Maryland
NoBoundaries's Avatar
1996 XLT
Vehicle Specs
Quoted: 8 Post(s)
(Original Poster)
Question
I was wondering if you all could help me.
I have the common problem of my temperature running too low (pretty much stays at cold) and I am going to replace the thermostat. Previous posts stated that this would solve the problem. I heard that I will need to replace the radiator cap so the gauge does not fluctuate, as has been a problem for many, but what else is involved? I also heard someone mention a new gasket, is this true? If someone could help me and let me know what I need, how I need to do it, and how much it will be I will be extremely grateful!!! Thank you ahead of time!!
Tim Y.
1996 Ford Explorer
NoBoundaries is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-05-2000, 10:05 AM   #2
CBoug76
Moderator Emeritus
ECX Member
Dracut, MA
CBoug76's Avatar
1997 Sport
Vehicle Specs
Quoted: 0 Post(s)
Post
If your thermostat is the same as in my 97 Sport, the Gasket is on the new Thermostat when you get it. The radiator cap only controls how much pressure is in the system, If I was you, I would not change the cap unless I were to replace it with a Cap that has the same Pressure Ratting.
[Edited by CBoug76 on 10-12-2000 at 06:34 AM]
CBoug76 is offline   Reply With Quote
Old 01-05-2000, 10:32 AM   #3
sluke
Vehicle Specs
Quoted: 0 Post(s)
Post
Tim Y
I just had my thermostat replaced Christmas Day. It had been running on the cold end of guage for quite some time. Finally it bottomed out and no heat from heater. My explorer is a 1991 and the therm cost about $11 and i had to buy the gasket seperate. I did not replace rad cap and i have no fluctuating(spelling?) guage at all. It was a relatively simple job, just a little tight to get to one of the bolts.
shawna l.
sluke is offline   Reply With Quote
Old 01-06-2000, 07:48 PM   #4
Syder-1
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
Talking
Hi Tim,
Replacing the thermostat is a very simple procedure, and it should take around an hour. I have a 1991, and the procedure would be a little quicker if it wasn't for that one darn bolt. I am not to familiar how the thermostat housing is on your truck, but regardless of that, it's an easy job. The thermostat (195 for plenty of heat) and gasket (if sold separately) should cost around $10.00. If you don't have a manual for your truck (Haynes/Chilton) I would recommend buying one. Good luck. Hope this helps.
Syder-1
doo doo happens
Old 01-08-2000, 07:01 AM   #5
darknight
Sterling Va.
94 XL
Vehicle Specs
Quoted: 0 Post(s)
Post
I just replaced my thermostat on my 94. It is very easy and is easier if you take off your intake tube and serpentine belt. The guys are right about that one bolt on the bottom though. Two things: If you get the therm. from the dealer, it will come with the gasket and the gasket will wrap around the therm. Second the therm. will have a little hole in it. The parts guy I talked with said that to make sure it is on the top when you put it in. It is a bleeder valve.
Darknight
darknight is offline   Reply With Quote
Old 01-08-2000, 06:30 PM   #6
Syder-1
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
Smile
Hmmmmmm. I was wondering what the heck that hole was for. Question answered...Thanx. I am also wondering if that would have something to do as to why the temperature guage would fluctuate if you don't have the hole at the 12 O'clock position?
Syder-1
doo doo happens
[This message has been edited by Syder-1 (edited 01-08-2000).]
Old 01-10-2000, 07:10 AM   #7
Dr.Doug
Vehicle Specs
Quoted: 0 Post(s)
Talking
Maybe the temperature gauge would fluctuate if you don't have the hole at the 12 O'clock position. The hole is designed for the trapped air in the engine to escape to the radiator cap to be vented into the over flow bottle. If your temp gauge is fluctuating after you changed you thermostat, replace the radiator cap. These should be replaced at the same time. They wear similarly.
Doug
Dr.Doug is offline   Reply With Quote
Old 01-13-2000, 11:57 PM   #8
nutboy
Vehicle Specs
Quoted: 0 Post(s)
Post
i have a 92 explorer and it was much easier changing the thermostat when taking off the fan belt and tensioner - better access to the thermo bolts. also, make sure you get out all the air in the system - that can cause the temp gauge to move all over.
nutboy is offline   Reply With Quote
Old 01-15-2009, 05:35 PM   #9
evofro@gmail.com
auburn alabama
1993 ford explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Syder-1
doo doo happens
dang, now that I think about it, I never did put my lil trap on the thermastat at the 12:00 position, cause Im also having fluctuating problems. Mine fluctuates from N(in Normal) to the R(in Normal) and it can be 30 degrees outside. Sure glad I found this thread though, I know what im gonna be doing saturday
evofro@gmail.com is offline   Reply With Quote
Old 01-17-2009, 03:08 AM   #10
Shaggy433
Sandusky, Ohio
94 Eddie B.
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by sluke View Post
Tim Y
shawna l.
so did it fix it? My gauge has always been bottomed out and the heat will work for a little while then just blow lukewarm....
Shaggy433 is offline   Reply With Quote
Old 06-20-2009, 10:32 PM   #11
Robrt32
Sledge Mississippi
94 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Did putting the little hole at the 12 o clock position help anybody?? I'm doing battle with the same thing right now
Robrt32 is offline   Reply With Quote
Old 06-22-2009, 01:37 PM   #12
Robrt32
Sledge Mississippi
94 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
I'm guessing it didn't help anyone...... darn, I was hoping...... I'm gonna put a aftermarket gauge on and get some real temps
Old 06-22-2009, 02:24 PM   #13
evofro@gmail.com
auburn alabama
Vehicle Specs
Quoted: 0 Post(s)
Quote:
I never did get around to turning my thermostat tap in the correct 12 o clock position. After replacing the radiator hoses cause they worn/swollen like hell, and the radiator cause it had a small pin hole crack. Eventually(even before I replaced my radiator) my temp hand stopped moving back and forth, and just keeps a steady temp reading of (N)ormal on the temp gauge, and unless I drive it for a constant 20miles at a time and then come to a stop light or just regular stop and go traffic then it goes up to the n(O)rmal on the temp gauge and I think it only goes to the n(O)rmal because I have a thinner radiator. Other then that I can't really say if that tab on the thermostat had any effect on mine at all. Lastly if you decide to put an aftermarket temp gauge, you think you could make a write up on how you did it
Old 06-22-2009, 02:34 PM   #14
evofro@gmail.com
auburn alabama
Vehicle Specs
Quoted: 0 Post(s)
Quote:
oh yeah and one more thing, you should keep and eye on your overflow tank, to make sure its not bone dry, and to check the rubber line running to it from the radiator. Also check your coolant level every morning just to make sure your not leaking any
Old 11-23-2009, 10:59 PM   #15
FarmTruk
Wallburg, NC
94 XLT 4x4, 172k miles
Vehicle Specs
Quoted: 0 Post(s)
Well, it looks like I'm replacing my '94's t-stat...again. This is at least the 3rd time, maybe 4th (160k miles).
Temp gauge has been stuck at "C" for the past summer. A couple of weeks ago, I noticed it would begin to run a little warm (not hot), but the gauge fluctuated wildly and rapidly. And the heat, while pretty warm, was not uniformly toasty.
Another thing I've noticed...the idle speed seems to creep up slightly when it's running warm. Normal is about 600-700 rpm. When running slightly warm, though, it can rise to 900-1000 rpm.
Anyone else noticed this?
FarmTruk is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Thermostat and Temp. Sending Unit Triton46 Under the Hood 22 04-19-2011 03:09 PM
Bad Factory Thermostat Install - Check yours if your mileage sucks briantf Under the Hood 4 04-08-2002 08:16 PM
replacing thermostat?? Quakecom Under the Hood 16 02-23-2001 02:38 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
