Go Back   Ford Explorer and Ranger Forums "Serious Explorations"« > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Body Work & Detailing
Notices
Body Work & Detailing Waxing washing, wheel cleaning and body work. This is the place to discuss those topics.
Rear Door Vent Window Replacment
Reply
Thread Tools
Old 01-29-2006, 04:45 PM   #1
KillerB74
Saskatoon, Saskatchewan
KillerB74's Avatar
'92 XLT
Vehicle Specs
Quoted: 3 Post(s)
(Original Poster)
My Explorer was broken into on New Years and the vent window was smashed out. I had a quote from a local glass shop for $180 cdn for the glass and replacment. I aquired a new window from a local wrecker for $40 cdn. This was my first time doing this and the job took 1 hour with no special tools.
1) Here is what I started with. You can where the exterior trim is bent from where the window was pried out. First thing was to clean up all the glass and clean the weather stripping out as there were lots of little pieces trapped. A flat screwdriver and the shopvac were used for this.
2)Remove the interior panel. A flat screw driver and prybar were used to pry out the clips. Next peel back the plastic dust barrier that covers the door.
Remove the bolt that holds the window guide. It is the yellow plated bolt (11 mm) visible in the picture.
3) With this loose you can pull out the weather stripping for all around the vent window and about half way down the door on the upper seal. This is where I was able to clean any remaining bits of glass out.
4) Install the window into the stripping. Slide it into the vertical channel first and then mold the flexible portion around the window.
Install the window sarting at the top and work the weather stripping back into place. I found it easiest to stand on the outside of the door and push the lip through to the inside. I used a flat screwdriver and needle nose pliers to get the rubber back into place. Just carefully work your way around without putting too much pressure on the glass. When the window is in push all the stripping back into place and reinstall the bolt that holds the window guide.
Put everything else back together and you've got it completed!
__________________
1992 XLT, 5sp
AAL, F-150 Spacers, custom built shackles, 3" Body Lift, Lock-Rite in front axle, 31x10.5 Cooper AT3's
2007 EB, 4.6L V8
K&N CAI with Amsoil filter, Flowmaster 70 Series, Steeda Under Drive Pulley, Henson Performance Tune
KillerB74 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-29-2006, 09:05 PM   #2
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL Pumpkin Edition
Vehicle Specs
Quoted: 445 Post(s)
Thanks for your article. It earned you 2 months Elite Explorer privledges
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
1960 Dodge Dart Seneca
Rick is offline   Reply With Quote
Old 05-03-2006, 12:09 AM   #3
Thetalkingshoe
Claymont,De
94 XLT
Vehicle Specs
Quoted: 1 Post(s)
Great thread. Some ####### broke into my X too and I need to replace mine. Thanks for the write up.
Thetalkingshoe is offline   Reply With Quote
Old 08-20-2007, 11:36 PM   #4
xdviper
Brooklyn NY
xdviper's Avatar
1997 XLT
Vehicle Specs
Quoted: 0 Post(s)
Hey, I had the same problem. Some kids broke mine and around the coney island park, there is a old used car glass store. got mines for 60$ installed.
__________________
Ford Explorer 1997 XLT
MY EXPLORER
xdviper is offline   Reply With Quote
Old 07-12-2008, 11:48 AM   #5
aggyaggy
LIVERPOOL,ENGLAND
98 XLT
Vehicle Specs
Quoted: 0 Post(s)
Smile
Many thanks for the advice , got it done in 2hrs.
aggyaggy is offline   Reply With Quote
Old 08-15-2008, 10:22 PM   #6
tta
1993 EB 1994 XLT
Vehicle Specs
Quoted: 0 Post(s)
What about the center part when they get rust in them? Are they hard to fix?
tta is offline   Reply With Quote
Old 10-31-2008, 10:34 AM   #7
Brandons
Ontario, Canada
Brandons's Avatar
06 F150 SC 5.4
Vehicle Specs
Quoted: 0 Post(s)
lol thats the window that always gets nailed... drivers side rear door. We had ours broken into back in 94, they stole a crappy camera but left the 10 disk changer alone.........
__________________
2006 F150 XLT Supercrew 5.4L
1994 XLT 4.0L
1997 XL 4.0L
Brandons is offline   Reply With Quote
Old 11-12-2008, 12:42 PM   #8
roxsox10x
california
1998 sport
Vehicle Specs
Quoted: 0 Post(s)
Just found this thread since mines was broken into too.
I thought it was odd that they broke into the rear vent window since it was so small but after researching it seems that most of the time that's the one that gets broken. I can't believe people do stuff like that man.
Then I noticed the marks on my windows and realized they probably pried it open too. It just sucks.
I got the window replaced but the glass is scratch and old because it was at a junk yard. Anybody know where I can order a new one and how much it cost. I'm thinking of replacing it later on. But the stupid pry marks are on the black trimming. Any way to fix that?
ANy suggestions?
roxsox10x is offline   Reply With Quote
Old 12-10-2009, 10:16 PM   #9
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
LMC truck...
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 02-25-2010, 03:07 PM   #10
itsallgod
Charlotte,NC
'94 xlt
Vehicle Specs
Quoted: 0 Post(s)
thanks for the support, i just replaced the vent window myself. got the window for $15.00... :-)
itsallgod is offline   Reply With Quote
Old 06-02-2010, 11:33 AM   #11
ginabina
ogden, ut
1991
Vehicle Specs
Quoted: 0 Post(s)
i need to replace the drivers side window in my 91, would any of u guys know how to do that?
ginabina is offline   Reply With Quote
Old 07-21-2010, 12:27 PM   #12
sioban81
Tracy, California
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Red Exp
Thank you so much for this write up. I am going out right now to replace it and can't wait to get rid of the metal piece my fiancÚ used to cover the vent window.
The vent window was broken when I bought the car at an auction.
I was able to go to pick n' pull and get replacement glass for $15 a couple of months ago but had no idea how to install it until I found this post.
Thank you again!
sioban81 is offline   Reply With Quote
Old 12-15-2010, 10:02 PM   #13
mysterymike
portland oregon
1996 explorer xlt
Vehicle Specs
Quoted: 0 Post(s)
Thanks alot! , im putting it in tommorow, mike
mysterymike is offline   Reply With Quote
Old 01-10-2011, 12:28 AM   #14
sneakyzebra
Battle Creek, MI
1996 Limited
Vehicle Specs
Quoted: 0 Post(s)
Thanks, Alot easier then I thought expecialy with pics and instructions
sneakyzebra is offline   Reply With Quote
Old 01-10-2011, 12:49 AM   #15
Mustangman66
Tolland CT
2003 4dr Explorer, v6
Vehicle Specs
Quoted: 0 Post(s)
Great post... thanks for the write up
Mustangman66 is offline   Reply With Quote
Old 04-04-2013, 07:15 PM   #16
OXNAR
Stannard Rock, Lake Superior
1980 Ford F-150 4wd
Vehicle Specs
Quoted: 0 Post(s)
Just the post I needed. Thanks guys. Spray the weatherstrippng with some Windex or other window cleaner helps the stripping go back into place easier, and cleans the window when done.
OXNAR is offline   Reply With Quote
Old 07-26-2015, 12:14 AM   #17
Scotsman01
Gold Coast
1997 Explorer XL Export
Vehicle Specs
Quoted: 3 Post(s)
Quote:
Just finished installing a new side glass, your post was a great help and I nearly missed the important part of how much of the upper mould to move. It made it easy and I thank you so much
__________________
1997 Ford Explorer XL
Scotsman01 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
